Wheel lift concepts - ideas and suggestions welcomed
So I'm trying to get my DD Supercar project rolling, and I wanted to make a poor man's version of a lamborghini fron end lifter:
Here's a sample of it in action:
http://www.youtube.com/watch?v=nZ1Sb5hQnCM
It's hydraulically operated, and works as a small piston or bag at the bottom of the coil to give it a few more inches of clearance.
I have a few ideas on how to do this:
1. Have a universal airbag on a set of front shocks or coilovers, but this would require extensive wiring, extra equipment such as lines, compressors, and valves. It would also have trouble in the winter, as the lines would freeze. It would also be expensive.
2. Take the hydraulic concept, but use one of these at each wheel:
http://www.harborfreight.com/cpi/cta...emnumber=36396
![](http://www.harborfreight.com/cpi/photos/36300-36399/36396.gif)
with an electronic 12v actuator as a pump, and a small motor to operate the valve. I can enclose it all in one unit and bolt it onto the wheel well area. I was thinking of having it push down on the control arm, and then retract when I release the air so I don't hit it on any hard bumps. I can probably make this for cheap, and I wouldn't have to worry about my lines freezing and by sourcing good motors, I can make sure i'm well within the reccommended duty cycle of the motor.
What do you guys think? I'm tires of scraping my front end on my driveway and speed bumps.
Thanks,
-Freddy
Thanks,
-Freddy
1JZ Single SC400
I would give this a try and lets us see the DIY pictures as you do it. Secondly, you could park it and buy another car for DD.. The bottom line is, I would say go for it!
http://www.umbrellaautodesign.com/co...ed_design.html
Umbrella has an application for Toyota Supras (Which will fit SC's) Check the coilover applications list on the site. You can run just a front setup, or full. This is made in America, quality kit- Lots of NSX Prime folks run this setup instead of the "Ooohh JDM" Roberuta cups.
Probably cheaper and more cost effective to just buy a kit. I wouldn't want some cheapy Harbor Freight hydraulic ghetto rigged into my suspension. Suspension travel + cornering + Mickey Moused made in China orange hydraulics just doesn't seem safe. But I'll say it again, DO IT MANG!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
seems kinda stupid. learn how to drive your car. learn to approach speed bumps with an angle and you wont have issues.
putting a harbor freight hydraulic cylinder in your wheel well wont really work. there isnt much room to begin with. the upper control arm is in the way of everything. even if you get it to fit, and it would be a miracle if it works your way, you wont be able to turn the wheels.
take off a wheel on your car and see how everything is set up and go from there.
BTW, I can have a continuous velocity solenoid that goes in and out to use as a pump, since it doesn't require that much force to compress the cylinder.
I'll take some measurements and see if it's even possible.
I'm trying to see if it's even possible, and I won't do it if it prohibits wheel movements or compromises handling in any way.
I'm also interested in seeing if I can make a suspension using oem components from an airbag-equipped car. Something other than the norm, basically.
