Another SC restoration. Making that 17 year old car look like new!
#151
They were $366 each with the Club Lexus discount at Sewell.
#152
Well, I received the rest of my parts order. I bought every suspension nut, bolt, and bushing I could find; knowing that rusty parts can be a pain to work with, this was/is a great help.
I was able to find a passenger side map pocket and new speaker grills, but unfortunately the map pocket was only available in gray. So, I sent the map pocket off to a vinyl shop to have it dyed, as that was my only way to get a new part and they assured me a near perfect color match. I had them redo the door armrests and they turned out excellent, once I receive the pocket back, I'll be ready to rebuild the door panels.
Suspension bolts, distributor caps/rotors, spark plugs etc.. If I were to do it all over again, I would say skip the upper control arm bolts (they were still in perfect shape), but they weren't that expensive.
Control arms, mounts, wires, and speaker grills... I learned in the process of swapping out my suspension parts that the upper control arms were still in great shape...oh well, now they are new.
And a sitting room full of parts.
I've started work on the suspension, first by removing the lower control arms. Only to find out the bolts through the rear cross-member are almost impossible to remove if there is any rust at all. I had to remove the entire cross-member and still was only able to get the bolt on the driver's side dislodged. I had to order a whole new cross-member to fix this little problem. It also makes me extra happy that I ordered all the camber adjustment bolts.
Here they are, attached as can be to my cross-member. It was an extra pain to remove with the control arms still attached. I also discovered there was some damage to the cross-member after I removed it, so replacing it won't be completely in vein.
#157
After your done with this project, maybe Sewell will buy the car from you to display it in there showroom. All I can say is WOW. Great job. What about the 99 SC400 your not gonna start on that one next. LOL.
#161
Thanks!
#163
#164
Waiting on some more suspension parts, so I decided to put together a freshened door panel with a new armrest, map pocket, and speaker grill.
Color is a bit saturated so the carpet and armrest look more yellow, but you get the idea. The armrest is a bit more tan than the original, but in normal light it's very difficult to tell.
