SC- 1st Gen (1992-2000)
camber correction kit & camber kit
Old 03-02-10, 01:57 PM
wagomaniac
wagomaniac's Avatar
Default camber correction kit & camber kit
Is there a difference between the two? I'm not familiar with these. I am looking to purchase the one that allows you to adjust ur camber.
Old 03-02-10, 02:10 PM
MIGS
MIGS's Avatar
im lookin for the same thing..
Old 03-02-10, 02:27 PM
TheKevin
TheKevin's Avatar
http://www.daizensporttuning.com/pro...tion-kits.html
potatoBBQ
potatoBBQ's Avatar
you would use a camber kit to adjust, i.e. "correct" your camber.
Old 03-02-10, 02:45 PM
wagomaniac
wagomaniac's Avatar
so this is what i need???
So its the same thing???
Old 03-02-10, 02:48 PM
GZZ-TT
GZZ-TT's Avatar
You can 'notch' the factory camber adjustment spacers to allow more adjustment- and no I don't have pics. (Should be straightforeward enough.) Just don't notch it too much so the metal will break, obviously...
Old 03-02-10, 03:08 PM
wagomaniac
wagomaniac's Avatar
oh ok thanks but im doing my suspension, getting coils replacing all the control arm bushings, so i would just rather get something new to replace the original 15 year old part lol. But i cant seem to find these things!. tmengineering said they dont have them in stock and that they dont know when theyre going to get them
Old 03-02-10, 03:26 PM
wagomaniac
wagomaniac's Avatar
ok so i was looking into buying Megan LP coilovers and was reading up on them. A website descripton said that they come with pillowmounts which allow you to adjust your camber. They said, "coilovers and camber kit in one". Is this correct????
Old 03-02-10, 07:55 PM
ConSynX
ConSynX's Avatar
I will list what I THINK, and someone else (or more than one person) can verify before you make your purchase.
The Correction and Camber Kit should be one in the same. The way the bushings are installed into the control arms will determine which one you "have".
Old 03-03-10, 07:42 AM
Biggu
Biggu's Avatar
correct.
our cars have no use for camber plates becuase the way the suspension was designed.
all the correction kit is a bushing that instead of being a single hole its either slotted or the hole is off center in order for the camber to be removed.
Old 03-03-10, 08:25 AM
shern
shern's Avatar
So who has Daizen camber kits in stock? I need a set for the rear.
Old 03-04-10, 01:09 PM
FutureSC
FutureSC's Avatar
http://www.tmengineering.net/suspens...n/make/sc.html
Old 03-04-10, 01:52 PM
wagomaniac
wagomaniac's Avatar
they don't have them in stock, I emailed them like a week agao and they said they don't know when they're going to get more
Old 03-04-10, 02:04 PM
vinh
vinh's Avatar
tm engineering hasn't had them in stock for a while.
Unless you are going really low, you won't need a camber correction kit. There is plenty of adjustment on the stock setup.
Old 03-04-10, 02:47 PM
wagomaniac
wagomaniac's Avatar
oh really? so you can run a lil negative camber on the stock camber?
Quick Reply: camber correction kit & camber kit
