Large cinder block in middle of road..
So I was happening to be traveling towards Sf Bay area yesterday. Right before the bay bridge. I notice there was something in the middle of the road. Looked like a piece of concreate or something. I had cars on my left side and right side, and one behind be maybe 15 feet away. Didn't want to slam my brakes.
I'm ussually pretty quick with my reactions, but there was nothing I could do but run it over. As I ran it over it went under and hit my transmission cross member mount. It caused my shifter to jump 4-5 inches high and drop right back down. Then I knew something was wrong.
Went home to check it, turns out the transmission crossmember bracket is cracked in half entirely. So now I gotta change out the mount.
My question is does anyone know if a auto tranny cross member mount will bolt in? or do I have to find a 5 speed? I tried searching and all I came up with is DIY's on how to change it which is pretty simple. Can anyone chime in?
Pretty dark outside right now, Ill take a pic 2m if at work. I believe the transmission mounts are different but not sure if the actual crossmember brace is different.. I can easily find a Auto, but finding a 5speed cross mount would be harder.
