fogs only work when i signal
I hav a 93 sc and my fogs doesn't work. But when they do, it's only when I signal. I signal right, right side fogs light up but not the left. Vice versa. Does anybody know what the problem might be? thanksss!
Yeah, they're corner lights. They're supposed to do that. You can convert them to fogs using a relay. The tutorial is on www.intellexual.net
They are both right..pre 95 SC's didnt come with fog lights, they are cornering lamps...as for the "faux fog conversion" in the link posted above, do it like that and you still have cornering lamps that light up the curb to your left and right, or do it the right way and retrofit like I did:
https://www.clublexus.com/forums/sc-...ner-lamps.html
The big difference between what I did, and doing the faux fogs, is when retrofitted, they are actually functional.
