SC- 1st Gen (1992-2000)
Speedometer needle calibration!
Old 03-10-10, 08:52 PM
TroySC300
TroySC300's Avatar
Default Speedometer needle calibration!
Long story short, I took off the speedometer needle and cannot reinstall it correctly. No matter when I do, it is reading 15-25mph lower than it should. I have removed and reinstalled the needle probably 30 times with no success! Anyone have any hints or tips?
Old 03-11-10, 11:27 AM
LEX_MAN
LEX_MAN's Avatar
If you have a GPS you most likely have a speedometer on it. If you dont have one then borrow it.
Get on the highway, cruise controll it at about 60 and install your needle
Old 03-11-10, 11:54 AM
TroySC300
TroySC300's Avatar
That's so crazy it just might work!
Old 03-11-10, 02:01 PM
BostonSC4
BostonSC4's Avatar
Wow, what a great idea. Never would have thought of that! I hope that works. How did it become misaligned? When I replaced my tach needle I just popped it back on there and its still very accurate.
Old 03-12-10, 12:26 PM
shern
shern's Avatar
Speedo needle can be adjusted. As mentinoed, I'd use GPS at a speed that matters (say 65mph) and calibrate to that speed.
Old 03-12-10, 12:47 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
If that doenst work, I would send it to Lextech, and let them try and resolve the problem.
Old 04-02-10, 12:05 PM
TroySC300
TroySC300's Avatar
Didn't work The needle drops down to the incorrect speed after I put it on...
Old 04-02-10, 01:56 PM
eliteskill
eliteskill's Avatar
I have that same problem with my temp needle. Doesnt seem like you can adjust it everything I do it set it in place it falls back into its settled position. (which is off by a bar) =(
Old 07-14-10, 06:20 PM
TRDmike
TRDmike's Avatar
Anyone found the resolution for the problem? Just changed the motors on my speed and tach and now my speed and revs are way off.
Old 07-14-10, 08:05 PM
romycha1
romycha1's Avatar
Hmmm... time to upgrade to some STACK gauges!!!
No but really, this is a good question because I think mine is off too.... when I'm cruising at 70mph, I'm passing everyone up like they are standing still.
Old 07-15-10, 05:54 AM
TRDmike
TRDmike's Avatar
I sent a email to lextech and got this as a response if i can send my cluster in to get fixed: "If stock, Those are just a matter of placing the needles back on correctly, not actual calibration in the sense of weighting and resistance changes to the motor itself. "
Any resolutions on how to fix it or send my cluster somewhere to get it fixed? I know getting another cluster would probably fix it but i would like to keep my 5spd cluster though.
Old 10-25-10, 12:06 AM
TroySC300
TroySC300's Avatar
Still haven't fixed this...lextech doesn't fix speedometers but has been helpful. I'm going to try replacing the entire speedo motor and spring with one from another cluster.
Old 10-25-10, 12:52 AM
kwg
kwg's Avatar
both my tach and temp is off. keep us updated if you have any new finds
Old 10-25-10, 10:26 AM
soarer13oy
soarer13oy's Avatar
i have a 95 cluster that went out on me when i tried bypassing a resistor. Im willing to part it out. LMK. All my needles were red and lit up. I dont know anymore because my cluster is trashed. I have a 99 cluster in mines now.
Old 10-25-10, 05:06 PM
KrazeMatik
KrazeMatik's Avatar
mine is doing the samething its 15mph off i was just wondering if anyone replaced the back bulb? i replaced mine to led and i believe that may of caused it to be all wacky
Quick Reply: Speedometer needle calibration!
