Push Button Engine Start
1JZ Single SC400
How come someone with so little posts, post something so great. This has been covered before but not a whole lot of pictures and details with the key position or wiring diagrams for us. Please post all the info you have. I have also a useless volume ****. Thanks
I just posted the DIY, hope it helps
here is a link just in case https://www.clublexus.com/forums/sc-...-ignition.html
I tried to address all the questions. let me know if you have more
To wire up a smart key and retrofit your ignition to act like the new factory ignition would probably cost quite a bit of money and would be rather complicated.
I think the key in the ignition with the start button to fire up the car is probably the best way to go.
Ryan
You would not want to set this option up even if you could. The way the new Lexus works is that the key sends an electronic signature to the ignition when in close proximity and this allows you to start up the car without the key in the ignition. If you were to figure a way to do this, you would set your car up to easily be stolen by anybody that broke in.
Ryan
Ryan
I did explain how it could be done in the DIY I wrote but I also strongly suggested against it.
Correct me if I'm wrong...
I really like this idea, but my question is that, could I can get any button and wire to the ignition switch? Engine start button is just a normal button and you can get normal button even smaller if wanted at radioshack. The button just sends the signal to ignition switch which will turn the starter and turn on the engine.
