does your SC wander at 80+ MPH
Wonder if anyone else experience this problem.
My SC has been wandering a bit lately when I'm driving on freeway at 80+ mph. Sometimes it makes me nervous.
Now it's dry in Calif so I'm not afraid of spinning but when the raining season comes I'm afraid it's going to be scary.
Bluegr*** Performance
You shouldn't have to worry about losing control as long as you maintain a solid hold on the wheel. I would suggest an alignment of the wheels - should not cost too much at a local tire place like NTB. There is also wheel balancing, but that is usually resulting in a wobble or vibration if the wheel is not balanced well. Check your tire wear, and inflation pressure also - though it is most probably and alignment issue.
AJ
AJ
Well the tires are fairly new. I'm very keen about tire pressure and wear so that's not the problem.
I never had this problem until I brought it to wheel works in the bay area for an alignment. It took them 4 times to get it right @#%$#$ retarded shop! The first time I got it back it wanders BIG TIME. It was so scary. Broght it back and it took them three more times to get the freaking job right.
Six months later I heard some noise when backing down the garage. The dealer checked and said some loose suspension nuts. They tightened it. I no longer have the annoying noise but now the wandering problem.
I guess I'll bring it in for an alignment.
Ask around town and call shops to see if they can handle your car. I can't beleive that shop your talking about. I would ask for money back but it has been a while.
Your wheel shop sound like a bunch of monkeys, take it somewhere reliable and get it checked out again.
The suspension clonk when you go backwards and steer or brake is a symptom of worn lower arm bushes, if they are worn this will give you instability at speed, that could also explain why the shop had such a job setting up your car.
It's my second set of Pirelli Supersport 7000, 225/55ZR16. When I firsted had them I experienced some shaking problem. But after the tires wore on the problem went away.
The tires last long. I like them very much.
