If it aint broke, don't fix it vs maintaining
How many of you guys, wont change something out until it's broke, and how many of you would rather maintain parts, changing them out at certain mileage as per manual
I like to kill 2 birds with one stone. For example, my stock suspension was perfectly fine, but I just bought a whole new TT suspension for the mods and since it only had 38k on it. Same with exhaust, it was flawless but I changed it out. So I guess you could say via modding, I'm doing preventitive maintenance.
I maintain my car rather changing out what doesn't need to be changed. It just turns out that the new product being swapped in is better than the part it replaces. Tires going bald? Belt on some Bridgestone footwork. Brakes pads squealing? Chuck those *****es out and get some Disc Italia ceramics...****, get some new EBC slotted rotors while you're down there.
well i work at an auto shop and like 90% of my friends are mechanics at other shops so that may have some effect on my choice
i wont fix till its broke but i always make sure i have money so when it does break its fixed immediately
I play it by ear.. If I know the car will be down for a week - month I will order other parts I want for it. Example: I was doing my r154 swap, didn't need a new transmission just because I know I will need it later. I knew it was going to take me some time because I worked on it a few hours every weekend, and I had to get some parts shipped/made. It took over a month to complete but... in that month I got my aluminum radiator, pulleys, electric fans and some other stuff. I also checked the plugs, cables, dist cap, and all the fluids and they were ok so I didn't change that stuff out.
Example 2:I know I am going to need to change out my timing belt and all other belts soon.. So I have other parts lined up for when I do this. Like my NA-t kit will be bolted up, piping, intercooler, cams, cam gears, fuel system, retainer kit (still looking), all the engine gaskets, and I might rebuild my r154 because my second gear is making a noise.
Once again I have DD so having my car down for a while isn't horrible. On my DD I do the maintenance and hopefully never breaks down.
When my differential went bad on me I just fixed it.
When I had my 95 SC, I changed several parts that were not broken yet. I wanted the car to run like a new car and it did. I believe that a 10-15 year old part can cause other systems to work harder when they are old. Changing things can prevent wear of other supporting parts.
When it comes to cars, the phrase "If it ain't broke, don't fix it" Is worthless.
It's bound to break or wear, so just replace it when and if you can.
Goodluck.
I spend money on the things that are most valuable to my cars health. It just so happens that they break before I get to save for them.
lol.
Goodluck.
lol.
I constantly inspect everything on used cars and don't go by the maintenance book. In most cases you can tell what needs or is going to need replacement. I like to do oil pumps right away because they don't give you warning and cause damage. I am very ocd when it comes to receipts for the cars I have now.....I'll save spark plug, wiring, light bulb, and oil change receipts just because.
Now if I were to buy a new or nearly new car from the lot, I would then start doing it by the book just because it helps resale value.
