Fog light HID installed
#33
question .. tried installing my hid fog tonight but got lost a little.... the 2 wire c metal clips.... the red is power and goes into a slot.. what is the black one for.. heard its ground??? so the fixed gray one is what?? what do i do with the black clip that comes with the hid...???
#34
Its plug and play. You shouldn't even have to cut/splice anything. It would hookup to the back of the cap/cover. You can see on the first 2nd and 4th picture I posted on page 1. Its pretty straight forward.
#35
#36
hey u mentioned u had found a spot to ground the black wire metal piece... where did u ground it???? i tried under a screw on the outside of the fog and the fog light just flickered.. maybe needs better ground...???
#38
wow its bluish at 5000k? Mines are 6000k and they are pretty blue too bad the fogs housing project the light everywhere so it isn't concentrated in one spot.. I accidently cut one of the rubber weather thing QQ but yeah it held up fine. The double side that DDM gives you SUCKS! I mounted both of them and went for a drive and they ballast fell off, luckily i had some extra 3m double side leftover
6000k 55watts for low beams and 6000k for fogs 35watt
![](https://photos-f.ak.fbcdn.net/hphotos-ak-snc3/hs513.snc3/26949_1277314021433_1487464073_30795730_2329410_n.jpg)
Thats the way i did it.
![](https://photos-a.ak.fbcdn.net/hphotos-ak-snc3/hs493.snc3/26949_1277313981432_1487464073_30795729_5817664_n.jpg)
mine failed
#43
I just seen the worst ways of installing HID's in this thread(no offense, but I say it how I see it), so I was forced to do a DIY..
https://www.clublexus.com/forums/sc-...ml#post7073275
