i heard you need a little resivior to hold gas and that you need an injector welded to your intake and when you step on the throttle the injector will inject gasoline into the intake manifold through the intake and it will shoot MASSIVE flames. Its pretty cool.
welded to the intake manifold? that wont do anything that's what oem injectors are lol they are int he intake. you need spark plug near the exhaust tip and propane jet near the spark plug.
ive seen a soarer shoot flames quite easily. no cats. get the exhaust hot, with some hard driving, and it will shoot flames out when you lift of the throttle..
when you're driving, keep your foot down the gas while its on neutral. rev till you stat hearing your engine make unusual noises, that means you're spitting flames! you can only do this once though
turbo the snot out of your engine and do a straight pipe, once the car is nice and heated up from some hard driving, its not too hard to get flames. a friend of mine was running cut-outs just after his down pipe and he got them every time we would go on hard road cruises at night, not sure how good or safe it was, but it wasnt too hard to accomplish with a strong turbo and exhaust mods
