SC- 1st Gen (1992-2000)
View Poll Results: What fuel grade
87
1.52%
89
1.52%
92
64
96.97%
whatever's cheap
0%
Voters: 66. You may not vote on this poll
What kind milk do you give to your baby?
Old 03-25-10, 12:16 PM
RedPhoenix
RedPhoenix's Avatar
who cares anymore, there has been many threads about this.
Old 03-25-10, 12:33 PM
xknowonex
xknowonex's Avatar
Premium only. Only 2-3 bucks more per fill-up
Old 03-25-10, 12:38 PM
RjBLayz
RjBLayz's Avatar
Always use 91
Old 03-25-10, 12:53 PM
TheKevin
TheKevin's Avatar
91. i wish we had 93 like those in other states
Old 03-25-10, 01:02 PM
TinCan
TinCan's Avatar
I don't use 92, because in the south we have 93, plus every thrid tank the lucas goes in too!!
Old 03-25-10, 01:09 PM
vietunit
vietunit's Avatar
Highest grade possible but you have to make sure the station is good, certain stations in certain areas aren't and have cheaper gas regardless of the brand.
Old 03-25-10, 01:10 PM
TinCan
TinCan's Avatar
I use top teir only shell chevron...
Old 03-25-10, 01:21 PM
FinalSC
FinalSC's Avatar
i tried racing fuel once! $8 a gallon.
Old 03-25-10, 01:50 PM
BostonSC4
BostonSC4's Avatar
Any difference?
Old 03-25-10, 02:04 PM
TinCan
TinCan's Avatar
hope it was unleaded
Old 03-25-10, 02:21 PM
infiniti24
infiniti24's Avatar
its unleaded in most places and there is no difference I could tell only a dyno would you really know and for the price is it worth it
Old 03-25-10, 02:43 PM
94_soarer
94_soarer's Avatar
93 all the way baby!!! i either get gas at sunoco, or on the military base
Old 03-25-10, 03:21 PM
//LRD
//LRD's Avatar
yo don't see a vote for 93 oct..
Old 03-25-10, 03:29 PM
scENFORCER
scENFORCER's Avatar
I use whatever's highest, usually 94. I've also noticed my car seems to run better on certain gas stations? Seems my car likes Shell the best. You guys notice anything like that?
Also, I've always wanted to try 100 Octane, or race fuel. But I was told that was a bad idea on a stock engine. It would harm it if anything because higher Octane's are too dry or something? Is this true?
Old 03-25-10, 05:34 PM
MAJones
MAJones's Avatar
Originally Posted by Klaus
Octane has nothing to do with quality. 87 octane is just as good of quality as 91 octane. The difference is in resistance to detonation. During the compression stage in a 4 stroke motor the mass of the air/fuel mixture stays the same while the volume is decreased therefore the temperature of the mixture rises according to Boyl's law. If the air/fuel mixture reaches the heat of combustion prior to the spark plug igniting, the mixture will detonate (hence detonation).
87 octane is typically safe on engines up to around 9:1 compression. 91 is the minimum recommendation for motors over 10:1 compression as the A/F mixture will become hotter on a 10:1 motor during the compression cycle vs a 9:1 motor. 91 octane has a higher heat of combustion than 87. This is not to say your motor will definitely detonate with 87, but under the right conditions it could. 91 it's far less likely.
Cliffs- use 91 octane on our motors that range from 10:1-10:5 compression depending on year
I just wanted to add to this with a quote from wikipedia talking about how octane is raised:
Where octane is raised by blending in ethanol, energy content per volume is reduced.
Given that and the previous information I would assume and have been told before that you would want to use the lowest possible octane that does not cause pre-detonation in your engine to achieve maximum power and the best fuel economy.
I usually run a mid grade because I do alot of hwy driving for work and spend a ton of money on fuel. In the winter when the air is more dense and the engine more prone to pre-detonation I use premium.
Also the higher the octane you run the quicker you will foul out your spark plugs.
Quick Reply: What kind milk do you give to your baby?
