SC- 1st Gen (1992-2000)
Will porsche wheels fit an SC?
Old 03-26-10, 08:21 AM
djrazr
djrazr's Avatar
Question Will porsche wheels fit an SC?
I don't know the lug pattern on a porsche, so i was wondering if porsche wheels would fit an SC? They're off an 01 Boxster
Old 03-26-10, 08:39 AM
Tabaka
Tabaka's Avatar
The bolt pattern on a Porsche Boxster is 5x130. The SC pattern is 5x114. You would need an adapter. It seems that the Boxster offers a variety of wheels. This might help with your wheel offset:
16" x 6" Alloy Wheel Standard Finish; 5 Spoke, Front 1997 - 2004 Porsche Boxster
with 50 mm offset.
17" x 8.5" Alloy Wheel Standard Finish; Forked Spoke, Rear 1998 - 2004 Porsche Boxster, with 50mm offset, Sport Classic wheel configuration.
18" x 7.5" Alloy Wheel, Bright Silver; 5 Spoke 2001 - 2003 Porsche Boxster
with 50mm offset, Turbo Look configuration.
17" x 8.5" Alloy Wheel Standard Finish; 5 Spoke Rear 2001 - 2003 Porsche Boxster 48mm offset, w/o recessed center.
18" x 9" Alloy Wheel in Bright Silver; 5 Double Spoke Rear for all 2003 - 2004 Porsche Boxster models, with a 52mm offset, Carrera wheel match made in heaven!
17" x 7" Alloy Wheel Silver; 5 Double Spoke Front 2003 - 2004 Porsche Boxster
55mm offset.
18" x 8" Alloy Wheel Silver; 5 Hollow Twisted Spoke Front 2002 - 2004 Porsche Boxster, 50 mm offset.
18" x 10" Alloy Wheel silver; 5 Spoke Rear 2004 Porsche Boxster
47mm offset.
18" x 7.5" Alloy Wheel Silver; 5 Raised Spline Spoke Front for 2003 - 2004 Porsche Boxster application with a characteristic 50mm offset.
18" x 9" Alloy Wheel Hyper Silver; 10 Forked Spokes Rear 2001 - 2004 Porsche Boxster
with 52mm offset.
17" x 7" Alloy Wheel Standard Finish; Forked Spoke, Front 1998 - 2004 Porsche Boxster with 55mm offset, Sport Classic wheel.
18" x 7.5" Alloy Wheel Standard Finish; 10 Spoke 2001 - 2004 Porsche Boxster
50mm offset, and grooved spokes.
17" x 7" Alloy Wheel Standard Finish; 5 Spoke Front 2001 - 2003 Porsche Boxster
with 55mm offset, w/o recessed center.
18" x 7.5" Alloy Wheel Bright Silver; 5 Double Spoke Front 2003 - 2004 Porsche Boxster, with 50mm offset.
18" x 7.5" Alloy Wheel Silver; 5 Flat Spoke Front 2003 - 2004 Porsche Boxster
with 50mm offset.
17" x 8.5" Alloy Wheel Silver; 5 Double Spoke Rear 2003 - 2004 Porsche Boxster
48mm offset.
18" x 9" Alloy Wheel Silver; 5 Spoke Rear 2003 - 2004 Porsche Boxster
18" x 9" Alloy Wheel Hyper Silver; 10 Grooved Spoke Rear 2001 - 2004 Porsche Boxster.
18" x 9" Alloy Wheel Silver; 5 Raised Spline Spoke Rear 2003 - 2004 Porsche Boxster
with 52mm offset.
18" x 10" Alloy Wheel Bright Silver; 5 Twisted Spoke Rear 2002 - 2003 Porsche Boxster , with 47mm offset; IXRC option called Sport Techo wheel configuration.
Old 03-26-10, 09:20 AM
djrazr
djrazr's Avatar
thanks for this
Is there a place to get adapters made that you know of?
Old 03-26-10, 09:46 AM
Tabaka
Tabaka's Avatar
Type "5x114.3 to 5x130 adapter" in google and you will find a few sources. It seems that they cost in the neighborhood of $180.00. Best of luck.
Old 03-26-10, 10:46 AM
turbodremz
turbodremz's Avatar
there is a member here using a set of Porsche wheels on his SC. Ebay sells the adapters, just not sure of the quality.
Old 03-28-10, 04:51 PM
boostgotme
boostgotme's Avatar
i justr got some bmw 18x10 wheels will post pics ordered the adapters from www.ezaccessory.com should be here wend but tires wont get on till friday ill post pics then
Old 08-31-15, 04:37 PM
TomSwifty
TomSwifty's Avatar
Did anyone ever end up doing this? I'm leaning towards trying it, I think it'll look great.
Someone did it with a Supra and it looks really good.
http://www.supraforums.com/forum/sho...fit-on-a-supra
Old 09-01-15, 04:30 AM
MackOnDeez
MackOnDeez's Avatar
adapters are cool and everything for different wheel applications BUT...
but dont expect to race around/ pedal corners like crazy with them. seen to many wheels fly off at tracks because of this...
cruising around is cool but keep checking them since they will get loose.
Old 09-02-15, 01:27 PM
Matt300ZXT
Matt300ZXT's Avatar
I'm not trying to be a jerk here, but if you can find Club Lexus and know how to make a post, surely you know how to Google "What is a Porsche bolt pattern".
jodo
IS F (2008-2014)
11-04-12 10:27 AM
speeds27
Wheels, Tires & Brakes Forum
11-02-10 05:38 PM
justinp95
03-18-10 07:46 AM
blkonblk17
03-27-06 03:24 PM
jamecl
04-17-01 04:38 PM
Quick Reply: Will porsche wheels fit an SC?
