SC400 Radio Installation
I recently bought a new radio cause mine died. The JVC KD-HDR50 a single din.
I went to install it the other day and had bought the brackets and pockets from Sonic Electronix http://www.sonicelectronix.com/item_...B+-Black-.html but the radio won't fit. I found the same model on bestbuy and other sites but im assuming their just all the same. Could you all direct you to a bracket system with a pocket I can used to install this radio.
Depending on the radio, that metra kit may need to be modified. I had to cut mine in half at the sides to compensate for a wider head unit than the kit allowed. It leaves no gaps and looks factory though with the metra kit.
You sure? They are usually pretty standards. If you notice, the aftermarket kits usually have lots of different holes there where you can mount the radio for it to sit right. Try again.
I had the same problem using a single din in my car. The radio itself is about 7" across which is the exact width of the opening for our stock radios. I ended up cutting 1 side of the metra trim off completely, and just putting everything in like that since it is such a tight fit.
But see this is my fitment
Very Sung and If I do cut 1 opening still might be good with the brackets... Bestbuy did recommend me a double din but is it not the same dimensions in width just most opening space to accommodate for a bigger radio or screen.
Edit: Cut it still wont fit around the sleeve of the radio going to get a new one im done trying to modd.
I might have to try that just going to be mad if it doesnt work cause I would have returned it haha
Well this is what im doing I did cut one of the trim on the metra kit. It just I cant fit it in the slot in the metra kit with the sleeve so im going to isntall without sleeve and it fits fine. But you say im trying to install it in the center... Well yes why is that wrong? Shouldn't the it be Climate, Radio, Pocket (Got the metra kit with pocket)
Remove the trim:
1. pPace the radio in the stock bracket or metra braket with or w/o the radio sleep, whichever fits best.
2. Place the Metra trim over the radio
3. Replace the center stack over the the Metra Kit
Here's pic:
The metra provided brackets were ment to replace the metal SC OE brackets. That's why it's not installing correctly, I just put a filler to hold up the pocket. Or install the whole by removing the metal brackets.
Sorry the pricture shows gabs but I recently had a wire run through bottom and hadn't had time to adjust it for apperance sake.
It's not going to be perfect but good enough for my 20 year 18 YO Car.
yeah i had trouble as well but i had a costume one made and
it was perfect i would show a pic don't got one now but tomorrow i will
the other thing that i had done was turning the volume *** into the bass control
Oh I know ^^^ but my biggest problem is I couldn't fit the radio in the slot of the metra kit as you notice its so tight. Basically edge to edge and I couldnt account for that .7inc on each side of the metra kit.
Or am I still misunderstanding ?
