most cost effective way to get 375rwhp out of 92 SC300 w/ 4 speed A430E?
you can do the 1jz trans pretty cheap, on my old 1jz car when i needed a spare trans i found several 1jz auto trans for 100 to 150.. some people give them away cause they use there w58 5 speed..
I say put a good trans cooler on, i'm using a B&M, then just drive it and don't worry about it till it goes out, then swap all the stuff you need from your bad trans to the 1jz trans and slap it in..
all that shimming the accumulators and increasing line pressure sounds great, but it's pretty time consuming and you really need to pull the trans out to do it, i personally wouldn't bother with that stuff unless your trans is already out!? it would be nice to do though..
anyways, id do the stuff ishootstuff mentioned, then buy a back up 1jz trans, when your stock trans goes out, swap all the stuff you need from your bad trans to the 1jz trans and slap it in..
What about the 1jz turbo auto trans?
Everything is interchangeable with the 1jz and 2jz trans?
So are you saying a 1jz trans would fit a 2jzge engine? is it a direct fit?..sorry, fairly new to all this. I assume the 1jz trans would hold more power than the stock 2jz trans?
i think all you really need to do is swap out the wiring harness for the valve body, cause the plugs are different on the 1jz auto.
dang, i must be lazy cause that sounds like too much work lol.. well plus i don't get to hang out with my buddies working on cars all the time like i used to, basically married now and have a baby so my car days are more limited now.. i personally plan on just going w58 or something if my auto goes out lol..
xs power might be selling products if you guys think is good, but I remember about 3-4years ago they werent so good especially with manifolds and the welding quality but for the price I guess is upto you.
