SC- 1st Gen (1992-2000)
1jz swap in SC400
Old 03-29-10, 10:07 AM
1jzchris
1jzchris's Avatar
Exclamation 1jz swap in SC400
Hey guys,I have a 1995 SC400. I did a 1jz auto swap, the car runs good,but i noticed that when i am cruising at about 60-65mph the RPM is kinda high at about 3500-3800rpm. Also when ever i floor it the rpm will run all the way to 8000rpm before it shifts gear,sometimes beyond if i dnt let up.
I am thinking its because of the Gear ratio in the SC400 and my fix will be to get a SC300 Diff. Any ideas or is anyone else having the same problem.
Also have a turbo log before 3400rpm,but thats a nother post,LOL.
Old 04-06-10, 12:13 AM
2jzLextasy
2jzLextasy's Avatar
i believe i read somewhere on the forums that if you do a swap in the 400 that you had tach issues. Not to sure probably need someone to clarify but i will look for the post.
Old 04-06-10, 07:42 PM
1jzchris
1jzchris's Avatar
the tach is working fine. The engine RPM is a bit high when cruising.
Old 04-06-10, 08:12 PM
Slow_Sc3
Slow_Sc3's Avatar
you have a 4.30 differential change it to the mkiv 3.73 or gs400 3.26 youll be much more happy.
as for the lag your twins are on the way out or you have a major boost leak.
Old 04-07-10, 09:47 AM
1jzchris
1jzchris's Avatar
Question
how about a sc300 differential,will that work.
Old 04-07-10, 02:35 PM
Slow_Sc3
Slow_Sc3's Avatar
pretty much the same thing as the 400 unless you find a 5 speed
Old 04-07-10, 04:25 PM
IOWNALEXUS
IOWNALEXUS's Avatar
Your tach is calibrated for a V8 and you have an inline 6 so even though it works it reads higher than it should. A stock 1jz does not shift at/over 8k and rear end gears have NOTHING to do with when the tranny shifts and wouldnt make that huge of a difference in RPM anyway. However it can make a difference on turbo spool, if the gears are too steep it wouldnt build boost as easily.but your tach is reading off so you are being tricked into thinking its spooling later than it is anyway, they are probably spooled up by 2500rpm you just dont know it LOL Go get a cluster from an SC300 and try that.
Old 04-07-10, 05:02 PM
snowfox444
snowfox444's Avatar
My regular 1uz engine does the same thing.. revs high, but no upgrades have been made? whats the difference between the motors anyway? Can you not turbo or supercharge the 1uz?
Old 04-11-10, 06:24 AM
1jzchris
1jzchris's Avatar
thanks for all the input guy,i am going to try to get a SC300 cluster and see if that makes a difference.
Old 04-11-10, 11:30 AM
vrsc400
vrsc400's Avatar
You could also try a tach adapter in the event an sc3 cluster is unavailable. I dont know about where you live but where I am it damn near impossible to find anything sc related!
Props on the 1jz-sc400 swap!
Old 04-11-10, 12:11 PM
1jzchris
1jzchris's Avatar
Tanx it wasnt a hard swap....................................I am in Miami so its not that hard to find SC parts.
Old 04-11-10, 08:47 PM
joeazy187
joeazy187's Avatar
im doing a 1jz swap in a sc400 as well and was wondering what you did to make the tach work
Old 04-12-10, 04:38 AM
RawkusX187
RawkusX187's Avatar
Some people just change to a SC3 cluster, it'll make it a bit more accurate
Old 04-12-10, 09:08 AM
Bubbas SC
Bubbas SC's Avatar
Can anyone direct me to a legit shop that can source 1jz's? I know of Jhot, but does anyone know of shops closer to California that has good reviews.
Old 04-12-10, 12:00 PM
RawkusX187
RawkusX187's Avatar
You should have many places local to you since you're in Cali
Quick Reply: 1jz swap in SC400
