Installing Lower Control Arms - Help
![](https://www.clublexus.com/forums/attachments/suspension-and-brakes/120204d1204931076-lower-control-arm-diy-img1.jpg)
To the right of the left 22mm yellow circle, there is a rubber spacer. Is that reused when installing new LCA? And is there only one?
Also what spec do you torque down the ball joint to?
No, it's like a flat, little, wrinkly, donut shaped piece of rubber that goes outside of the bushings. Far as I know, you can't buy them anymore, so I just put the old one back on ... even though it does absolutely nothing anymore. Was it maybe a dust ring/collar originally???
Swedish
10-04-18 04:35 AM
EUROJulian
Suspension and Brakes
82
05-31-04 12:55 PM
