2JZGE Na-T TT Ecu Mod
#1726
Is it possible to do this modification to a UK spec TT ECU?
Looking to go NA-T on my 93 JDM N/A 5 speed supra and have just picked up a set of non vvti coil packs and a UK supra ECU (6MT). I'm running an FFIM so not worried about clearance on the non vvti coils. Will be running 550cc rx7 injectors so the UK ecu seemed to be a good option as UK's came with 550's but I'm struggling to fill in the gaps..
Do the UK spec supra's have a MAF sensor like the USDM ones? How will this work with my car not having a MAF? What ignitor should I use? Will the wiring diagram on page 1 still apply?
#1727
So I didn't read every single post and page but I have been browsing for some time now and haven't found an answer so figured I would just ask.
I was wondring what all I needed for the TT-ECU MOD .. I am currently in a 97' non-VVTi Auto. I have everything I need to swap for forced induction however correct me if I am wrong here.. I need :
Parts:
USDM 2JZGTE ECU for an A/T ( out of a 96-98 non vvti TT supra)
DS62 Ignotor
TT MAF
Wala!! little bit of wiring following the original diagram minus the two extra wires to the ecu from the ignotor and I'm good??? Right?? That's what I have gathered there.
My main question is will the stock A/T still work fine with GTE A/T ECU or is there some sort of patch I need to do?
Just trying to eliminate all complications before ripping into the car .. Any help would be greatly appreciated as I just found all this info out days before starting my NA-T swap and has caused quite a headache lol
Parts:
DS62 Ignotor
TT MAF
#1730
Just buy the right injectors and you won't have to worry about it...it's not a big deal.
And for the last time, You guys need to search stop coming over here cluttering this thread with the same questions,Read this thread from page one.
#1732
UK is the same spec as JDM as far as I know.
There are only 2 versions.
USDM = maf sensor and a map sensor which uses 550cc stock.
JDM = Only a map sensor and 440cc stock.
The rest of the countries are just a copy of one of the 2 above.
If your has a maf sensor on the intake, then its similar to USDM, so see the info in post #1.
If your does not have a maf sensor on the intake, then its similar to JDM.
If its similar to JDM, then you should already have a map sensor and IAT installed on your n/a since the n/a does not use a maf either on JDM vehicles. just swap out the n/a map sensor for the TT map sensor (different ranges), IAT you can re-use your stock one. install all the rest of the ignition and injectors the same as USDM. basically the map sensor and IAT are already wired when doing the mod on a JDM n/a vehicle.
Parts:
DS62 Ignotor
TT MAF
Parts:
DS62 Ignotor
TT MAF
If you don't need to do emissions, just do the odb1 version of the mod but the map sensor wiring will be a little different from whats on page 1, as the power wire for the map sensor cannot come from the old maf power wire and must come from the tps 5v blue red wire, as the newer maf's are 12v not 5v like the old maf's where we can reuse all the wires including the power wire.
for the auto trans, odb1 only thing that isnt working is the torque converter lockup solenoid, which we were working on a relay for but its not confirmed working. Trans will shift through all the gears just fine though, just the lockup not functioning. You can either plan on figuring it out or swapping to 5 spd or a gte auto trans but then remember some additional wiring for the new trans will need to be run as those wires arent on your harness already.
you can search online for both diagrams individually but from on to the other might be difficult. there was a spreadsheet in the aristo nightmare wiring thread I suggest you do a search first.
start with what you have (US or JDM GE, odb1 or odb2), what you need (have to be emissions friendly or not, map sensor based or doesn't matter.. etc), what you want (stock coil or multi-coils.. etc..), and then the choices are easy.
I don't think he was talking about you bud
#1733
I'd rather just swap out lower manifolds for cheap than spend a ton on injectors that will still have a question mark
edit: Even then...I think I'm just gonna sell everything and keep the car stock. Even with the correct lower runners to match the injectors it wont run right...at least thats according to buffnstuff's experience.
I dont care about staying OBDII so what all is involved in going the OBDI route and will that actually make a difference?
#1735
#1737
you can always do the obd1 version on an obd2 car and run off a map sensor JDM ecu, which id less picky about boost leaks.. etc... just your obd2 port will not work. so its like using a standalone that won't pass emissions by itself.
Yes thanks for the info on that, I really like my new shiny cap =)
I wonder if throwing a map ecu ar vpc on there would help, it would eliminate the maf and run everything off a pressure sensor, but that more wiring to possibly mess up.
In for more updates though lets try and get this odb2 stuff working, I am sort of bummed its not working for you guys, but it could totally be something simple, its the nature of this kind of diy.
#1738
I reaaalllyyy think that its a matter of driving the car and letting the ecu do all the work. That is my gut feeling on the issues that buff is having. Once myLEX gets his leaks fixed I figure he should do the same.
edit: In vacuum of course. I wouldn't try seeing positive manifold pressure until it drove in vacuum like a stock car THEN try to boost.
#1739
That really good advice, but once you get it running the excitement kicks in. usually it will either boost good or not at all, but yeah getting it perfect in vacuum is always recommended first especially with maf cars.
I hope you guys are using T bolt clamps on those couplers and real couplers. If you use those worm gear clamps from the store you are asking for leaks. if its not 3-ply coupler do not try and put it on the stock throttle body you will melt it right away. 3-4 ply will last maybe a year or so and get a small hole in it from turbo heat. with a turbo blanket and 3-4 ply with the stock intake it will last a long time (my stock intake setup).
#1740
For the guys still on the stock intake manifold and throttle body. Are you using block off plates to eliminate the EGR? Does the EGR create a boost leak in positive boost conditions? Does anyone sell an inexpensive block off plate? Powerhouse Racing's kit is $90!
