2JZGE Na-T TT Ecu Mod
#1861
So I have decided that I am going to swap out the stock auto with a tt auto to keep the ecu happy. The wiring I did for the lock up converter did not work so my trans is over heating if I go on drives longer than 20 minutes or so. A local shop quoted me $900 to do it including the trans because they have a few laying around from swapping supras to v160s. I'll just have to do the wiring myself. Still can't locate any wiring diagrams for the transmission on a 97 tt. I'll probably just run new wires from the trans to the tt ecu.
I think this is probably the easiest/cheapest route for anyone with an auto obd2 car running the tt ecu mod. The new trans will be able to hold the power level I am at and it is what the ecu wants anyway.
My question is, since one autos shift solenoids are electronically controlled and the other is controlled by line pressure, how to I go about this conversion? Can anyone post a link to a tt auto swap? I searched for quite a bit but came up with next to nothing.
So just wondering if this TCC Relay mod has worked for anyone?
It is just converting the 12v signal (SC-Ecu) to ground signal (TT-Ecu) to keep the TT-ECU happy right? I couldn't imagine the Relay not working then.
WE NEED A BREAK-THROUGH FOR OBDII AUTO GUYS!!!!!!!!!!
#1862
Been reading up and doing research for a NA-T conversion in the future, but more importantly I love the fact that I can swap the ecu and do the ignition without having to do the full blown turbo kit all at once. I am having issues with my stock 95na ecu so if I need to replace stuff, it might as well be towards my end goal.
Just to verify, there doesn't seem to be any advantage to spending the extra $ on a tt jdm 6sp ecu now right? Just grab the aristo (auto) tt ecu and pull that one wire and there's no other downside?
well this definitley puts a hold on my project as it is my daily and takes more then 20 mins. to get to work, and I make frequent HWY trips to visit family about 50 Miles away.. Can't afford to smoke my trans..
It is just converting the 12v signal (SC-Ecu) to ground signal (TT-Ecu) to keep the TT-ECU happy right? I couldn't imagine the Relay not working then.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
the lockup converter seems to be the only real function that doesn't work right away. the line pressure is still being controlled by the throttle body, so I will have to ask one of you guys with an auto car to step up and do some of my sort of pioneering in relays and swapping stuff, as I cannot really do it myself looking at diagrams, 50% of my aha moments come from playing around with the things physically. maybe when you do start Aswilley I can take a look at it.
when I started this mod I really didn't even think about auto transmissions at all or if they would work. honestly the stock auto wont last any good amount of time boosted. I suggest you guys factor the cost of gte trans upgrade or manual swap into the price of na-t, as even with the lockup working you will be on borrowed time with that trans anyways.
#1863
on another note, I have torn down the motor again to do a new FFIM install and rework some stuff I needed to wiring wise etc..
a problem I had previously is that after hard runs I could smell the oil cooking, which didn't bother me that much cause I change it frequently, but then it hit me that I don't have to use an aftermarket oil cooler.
So I bought a 2jz-gte factory oil cooler with the whole oil filter mount, and I am pretty sure its a bolt on type of deal except it has 2 extra coolant lines to cool the oil. well what I figure is that I have the 2 hoses from my throttle body that are capped off, so I will put them to use and run those throttle body coolant hoses to the oil cooler. that way the lines are used up nicely and I get a factory gte oil cooler.
I know the big front mount oil coolers are like better or whatever, but I just want the basic keep oil from completely cooking oil cooler and I am pretty sure the factory one will do just that pretty well. If I have to upgrade the radiator I rather do that then have oil lines going everywhere. will update once I get it on the car.
It looks like this and this is a picture of a gte I think. I am wondering if that hard pipe from a gte would fit the one that goes around the back of the block, or I will just get some good quality hose and wrap it in heat shield stuff.
![Name: motorquestion.jpg
Size: 52.3 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/424626d1501303113-2jzge-na-t-tt-ecu-mod-motorquestion.jpg)
#1865
Okay so clubNat.com is back up so that helps a lot. Basically the transmission for the tt is electronically controlled and the sc300 auto is line pressure controlled so it sounds like there isn't any complication there since I will just have to wire the tt auto up to the tt ecu and not have to worry about the line pressure part.
how long has clubnat been back up? That was a wealth of information that disappeared for a while.
#1866
... Thats what I thought it was as simple as changing the type of signal like with the a/c relay, but something must be happening different. maybe I got the wiring on the relay wrong or did any of you guys look over/double check it? maybe a different relay is needed? In theory it should have worked
only other solution is that one could try the actual GTE sensor on the GE auto but not sure if its a straight swap out sort of thing, I know the trans are very similar in overall design so it could be *crosses fingers*.
I just relized that TCC for our cars are on a duity cycle.. meaning that a relay cannot control signal at all and will never work, because you cannot put a percentage charge on an relay and it work.. it is either on or off.. The ECU is looking for "slippage" achieved by cycling the solenoid on and off in a duity cycle inorded to have smooth transision between "free-spin" and "lock-up" .. if it didn't cycle it the relay would turn on and it would be an extremely harsh engagment and probably do harm to the trans.
Since this is the case the only plauseable way to achieve TCC is to reverse the polarity to the selenoid and hope that it would work... ONLY PROBLEM !! - the GE TCC selenoid body constrution is 1 wire 12v signal and grounded through the selenoid body.. so you wouldn't be able to revers polarity cause it wouldn't work unless it was a two wire.. in theroy you would actually need a whole new selenoid and hope it matches/ values same/ fitment/ all sorts of other problems to encounter lol..
Form what I can tell so far is the JDM ECU sends 12v to the selenoid via duity cycle from ecu inputs.. some cool stuff happens inside lol.. the ground is sent back to the ECU via a second wire, where at that point the ECU finishes the curicut inside the control unit
I hate wiring lol.. this took a while to come up with so let me know if this makes sence..
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
#1867
the injector thing, well they showed that you can use the obd1 injector on the obd2 rail, it will seal still even though its not the perfect o-ring. they said up to a certain amount of boost though generally speaking though if it seals it seals so I would think its fine then.
getting an older lower runner or newer style injectors is not a bad idea but for simplicity sake it turns out you can use the older injectors on the obd2 runner originally I was unsure and I had only suggested changing it out because the 2 people trying it were both having similar trouble getting it working and i figured it was a possibility. turns out it was something else though.
just went there I can open the links and everything. be cautions there is also good info and bad info on there. I wonder if my link in the first page is working again.
#1869
Hey guys, I really think I'm either going to give on on this car completely and sell it, or save up some money and go stand-alone, because I'm just completely fed up with this car.
After my misfire codes came back a couple weeks ago, I took it to another shop where they replaced all the vaccum lines, replaced my copper plugs with low-gapped laser cut irridiums, checked the coils, cleaned up the wiring for the COP conversion, and cleaned my IAC (it was filthy and making squeaking noises). I picked up the car the other day, put 70 miles on it and the codes are back.
-random misfire
-misfire on cylinders 2,3,5,6
The car makes a loud whooshing air sound between 3000-4500 rpm and just does not accelerate during that time. Then it pulls past that from 4500-6000 at which point whats the point? I lost in a stop-light drag race with my dad's stock Chevy Colorado Xtreme. Thats embarrasing. Oh, and the boost spikes at 12psi for some reason even though my MBC is supposed to peg it at 10psi. IDK whats wrong with this car...... Im so broke because of it.
Literally everything in this car has been checked through by 3 shops and everyone is stumped why this doesnt work and everyone says just go stand-alone. I spent ridiculous amounts of money on labor, and the car still runs like crap. What am i missing???
Or am I too much of a perfectionist? I mean the car is drieveable and doest die out. Is it supposed to run like stock and boost linearly? Is the idle supposed to be around 700? (mine idles at 950 only when fully warmed up and boosted).
-random misfire
#1870
-random misfire
-random misfire
Your issue sounds mechanical. Going standalone will not resolve the issue. Did you match you BOV spring pressure to your vacuum levels?
This would also explain why you are fouling your plugs and getting missfires. You're loosing all that metered air and running too rich in boost.
#1871
Ali, so i'm not completely sure but check this theroy out
I was not aware it was a duty cycle type of signal. I thought it was a regular on or off signal since the online guide says the GE puts out a power and the gte puts out a ground.
It could be that the ge one is simpler and the gte one is duty cycle so I will try and look into it.
If its duty cycle then the relay would likely not work.
Not sure you would want to even bother making a circuit to take the duty cycle and output a signal, it really seems like the ecu should do this but if that is the case then what I would do first is just get the gte solenoid and see if its a direct swap out as these trans do share the same trans code there is a chance it may fit.
you probably need to drop the pan on the trans, but then if it is just a matter of swapping it out and jumping a standard power wire from an adjacent sensor that would be a good result.
-random misfire
-random misfire
Did you yourself make sure the timing was set right with the tps in the right position where you heard the engine change sound when you put the jumper in?
if you are idling at 900 without the a/c on then it sounds like its not entering the idl part right, a gte ecu entering closed loop on the stock intake will idle down to 650 with the a/c off with the tps in the right position, and usually around 900 or so with it in the wrong position. remember you also cannot set timing with the tps in the right position. If when warm you don't see the rpm meter going from 900 down to lower after you come to a stop (usually takes 3-5 seconds) your tps is in the wrong position.
#1872
Turns out you were right on the GTE ecu it is labeled SLU- which is a newer type of duty controlled signal probably used on the gte and then later on most obd2 vehicles.
The GE uses S3 signal for this (S1 and S2 are the shift solenoids) so that tells us along with them moving the pin over that the old signal was likely the simple on off and the new one is duty cycle controlled (will double check on the GE setup).
you can see the description on this from the FJ cruiser I found online except this one is wired differently
http://www.purefjcruiser.com/docs/20...em/0170033.pdf
http://www.bluegrasstoday.com/wp-con...0e_shudder.pdf
It also says the ecu uses the speed sensor NCO which is present on the GTE pinout as the overdrive speed sensor, but is not present on the GE pinout, I am not sure if this is needed for the ecu to drive the torque converter lockup.
Plug 21 NCO+ Over Drive Direct Clutch Speed Sensor Input This pin is used to detect the speed of the automatic transmission O/D input shaft. The fuel injectors are electronically controlled by the engine ECU. This pin connects to the OD speed sensor located on the left, front side of the automatic transmission and outputs ? pulses (reluctor pulses) per revolution of the OD direct clutch drum.
if the overdrive is working though there may be some sort of bacup or failsafe for this such as one of the other 2 speed sensors, so I would just try swapping out the solenoids and hope it works without it or it may be entirely possible that you cannot use the variable lockup on the older trans or whatever, I have a very basic understanding of the auto trans's but I have a good understanding of electronics.
still trying to find a waveform diagram for the 2jzge transmission S3 lock up solenoid.
#1873
2jzge lock up solenoid (1 diagram) followed by 2jzgte lock up solenoid (2 diagrams)
pretty clear now the GE is on/off it says it opens when power is applied that is it.
The GTE is variable as it says it moves in and out as variable power is applied.
you could in theory reduce the GTE one to simple on/off by having a circuit ouput battery voltage when the duty cycle is above a certain amount.
I guess that is the circuit that is really needed to use the old one...
or if the GTE one fits since its variable might be better although I also see the GTE has a 4th solenoid called back pressure accumulation also which the GE is missing... not sure if they are related or not.
#1874
All the more reason for me to swap to tt auto and not fiddle with it Lol. if I had the money, I would swap to 5 speed but it seems that can't be done for less than 2k. I'll roll around on a tt auto for awhile until I can afford an r154 swap.
