Will these fit as far as tires go?
265/35/18's 17 offset
295/3518's 17 offset
Car is stock tt supra suspension so .5-1" lower than stock
thanks
thanks
Youll probably need a lot of modifying to your front fenders. The rears will also need to be rolled. Im running 245/40/18 in the front and 285/35/18 in the rears. All m y fenders are rolled.
1JZ Single SC400
I dont see how if your not rolled. Whats your your rim offset? I think you could run them, with a little bit of grinding on the inner lip in the fenderwheel compartment. JMO
Why not?? As long as the offsets fit the car then you will be fine. I am running 255/35/18 F and 295/30/18 R and I didnt have to roll or pull my fenser at all...All I did was get a alignement!
i have 18x10 255/35/18
and 18x11 265/35/18
my rears rub...
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
i was thinking of running 245/40/18 in the front and 255/35/18 in the rear....
any experts out there to give their 2 cents on stability and safety?
I essentially just dont want my tires to catch in case my suspension gives out and puts me into the wall....
looking cool is important and all ....but i'd rather not be smashed into the center divider as well....
SylvesterM
01-10-18 07:15 PM
madmax66
07-30-08 05:20 AM
Macgyver
Wheels, Tires & Brakes Forum
04-20-06 10:20 PM
