SC- 1st Gen (1992-2000)
Picked up a 92 SC400 and car has no power HELP
Old 04-21-10, 11:54 PM
  #31
LS400JDM2
LS400JDM2's Avatar
any one knows what else i should check or what it can be?
Old 04-23-10, 02:53 AM
  #32
sagikun
sagikun's Avatar
i dont know what kind of answer your looking for. its most likley the TPMS. but you dont want to hear it
Old 04-23-10, 03:08 AM
  #33
sagikun
sagikun's Avatar
Thumbs up
Originally Posted by ProjectSC3
Check your fuel pressure. It should be at least 40 psi.
Also you could check the resistance of your coils using a multi meter. I can get you the specs when I go to work tonight.
Disconnect ignition coil No. 1 electrical connector.
Measure resistance across primary terminals.
Should be 0.40 - 0.50 ohms
You can test that but I don't really think it's a coil. It sounds like a fuel issue. Check the pressure and look for any leaks. They may be really small. And it wouldn't hurt to try a fuel system cleaning.
Yeah if your coils are bad it would run really rough all the time.
I don't think it's the TPS because you only have this problem when your in gear and the engine is under load right? If you can bring the rpms up when your in neutral just fine then the tps sensor sounds like it's working. Now if this problem occurs both in gear and in neutral than yes I might be a tps sensor. If you have some sort of scan tool that shows data it is really easy to check the sensor.
And if you want to be sure that it is not spark related just go pick up a cheap spark tester from a auto parts store and just check it at every wire before the plug. I think there like $5 and there very easy to use.
Old 05-01-10, 10:11 PM
  #34
LS400JDM2
LS400JDM2's Avatar
Replaced with a used one in good condition same thing! ??
Old 05-09-10, 07:28 PM
  #35
GS300_1996
GS300_1996's Avatar
have yo found a solution to your problem yet?
i have 96 gs and is doing the exact same thing and another surprising thing is that my car as well was parked for a few months and now its back on road without power....
Old 05-09-10, 09:00 PM
  #36
willhickey
willhickey's Avatar
did you ever check the timing?
Old 05-10-10, 09:15 AM
  #37
GS300_1996
GS300_1996's Avatar
timing is good.
no MIL or whatsoever...
Old 05-10-10, 05:26 PM
  #38
ToyotaMike
ToyotaMike's Avatar
You replaced the TPS but did you adjust it correctly?
Old 05-18-10, 09:46 PM
  #39
LS400JDM2
LS400JDM2's Avatar
nope it is still hestitating jerking when past the 2500 k rpm mark in gear,but one time i was low in coolant to the point the car was starting to heat up at night , but at that time the car accelerate rather smoothly1!??
They say it can be my crank sensors?
I have not checked the timing since the timing belt may need to be replaced anyway.
I did replace the tps with another one still the same thing!
  #40
LS400JDM2
LS400JDM2's Avatar
Smile
nope i have not buddy i will check the engine code again tomorrow after a reset!
Old 06-03-10, 07:49 AM
  #41
LS400JDM2
LS400JDM2's Avatar
Cool timing off two teeth the mechanic says
Originally Posted by 1995Lexusc
There could be a few things. Bad coils, Open wires pinched between the cam covers, bad MAF, Timing off by a tooth etc. Keep checking it thoroughly.
HEY DID all wires , spark plugs , distributor cap and rotor, ignition works fires , it idles fine and very smooth until up to 2500 rpm when it sputters and no power while in gear.
I have had the car diagnosed and they say the timing belt is off two teeth!! I am going to replace the t belt today by my mechanic. CAN that be the cause of it having no power past 2500 rpm approx and sputtering past that. thank you
Old 06-03-10, 07:53 AM
  #42
LS400JDM2
LS400JDM2's Avatar
any one ???
Old 06-03-10, 12:43 PM
  #43
LS400JDM2
LS400JDM2's Avatar
anyone? let me know thanks
Old 06-03-10, 12:54 PM
  #44
Photon440
Photon440's Avatar
Two teeth out? Definitely a big problem there. That'll not only affect your ignition timing but your cam timing as well. Was it out two teeth advanced or retarded?
  #45
toy4life
toy4life's Avatar
check your ignition wires you might have them cross up.
Quick Reply: Picked up a 92 SC400 and car has no power HELP
