SC- 1st Gen (1992-2000)
450hp feasible on stock turbos 1.5JZ ?
Old 04-10-10, 11:50 AM
FuMoFFuTT
FuMoFFuTT's Avatar
Default 450hp feasible on stock turbos 1.5JZ ?
There's a Soarer that is trying to sell for $20,000 and is claiming 450hp. But from what I can see in the pictures the turbos are stock. Here's what he listed..
-1,5jz Motor
-Bloc moteur de 2jzgte 3,0L aléser avec Piston, ring, pin forger de marque JE Forged,
- Head gasket HKS and all the engine the seals are new
- High flow oil pump
- 3" Exhaust 3" straight going into 2.5" inlet and 3.5" outlet muffler
-Cold air intake
-Turbosmart adjustable wastegate
-new Main bearing and rod , valve radius SDP,
-Head bolts ARP
-Front mount intercooler
-Aluminum radiator
-new Timing belt and tensioner
-Titanium retainer
-new coilpacks
-adjustable gas pressure regulator
-ACT Extreme clutch
-Urethane motor mounts
-Mag 19'' de marque Blest-Bakusport,
-Suspension TEIN confort-sport,
-Apex'i super afc neo, et Apex'i rsm,
LINK
http://montreal.kijiji.ca/c-cars-veh...AdIdZ196759837
Old 04-10-10, 12:35 PM
nfordhk
nfordhk's Avatar
does he got a dyno? Maybe 450whp?
Old 04-10-10, 12:43 PM
FuMoFFuTT
FuMoFFuTT's Avatar
No he's talking 450hp at the engine.. but is that really possible?
Old 04-10-10, 01:10 PM
Matador
Matador's Avatar
So he's got like 360 or so whp. With a good tune stock twins can still make some power, I think Biggu it putting at least that much down. That being said, I dont know if that particular car is making the 450 it claims.
Old 04-10-10, 01:20 PM
FuMoFFuTT
FuMoFFuTT's Avatar
The car itself is pretty clean. I updated with a link
Old 04-10-10, 06:01 PM
InhumaneSC
InhumaneSC's Avatar
Ah, stay away from the stock turbos, their pretty fragile and can't support much higher than stock boost. Their ceramic too not stainless steal so if you blow a turbo all of the ceramic shards from the wheel are going to get sucked right into your engine and ... BOOM. My first mod would be a single turbo you can find a decent turbo manifold for a single turbo relatively cheap..PM me and i can help you find a cheap one.
Old 04-10-10, 08:40 PM
Slow_Sc3
Slow_Sc3's Avatar
BS!!!!
i dont believe this is true
Old 04-10-10, 08:42 PM
vietunit
vietunit's Avatar
On stock turbos, I don't believe it.
Old 04-10-10, 08:48 PM
93sc3005sp
93sc3005sp's Avatar
on usdm twins then sure
Old 04-10-10, 09:21 PM
attzor
attzor's Avatar
It's a 1.5jz, theres no usdm twins, its 1jz twins on a 1jz head.
Old 04-10-10, 09:29 PM
v8soarer91
v8soarer91's Avatar
soarer tt ceramic tubos - hell no
"USDM haha"
supra steel turbos - no the boost needs to be to high for the turbos to handle, even at 3ltr
aftermarket small turbo tt install - yes, but still pushing the turbos.
aftermarket single turbo install - yes definatly.
suspect parts
"high flow oil pump" - only JUN or Toga (sh*#) makes them
3" exhaust - too small for the power
only using an Apex'i super afc neo for tuning
Old 04-10-10, 10:13 PM
Dr.Fate
Dr.Fate's Avatar
Man I'm not seeing it, 450 on stock turbos? We are more likely Malcolm X and Martin L. King VS. Ronald Reagan and Hitler in a no holds bar cage match with two guest Ref's, Marvin gay and Ted Nugent.
Old 04-11-10, 12:15 AM
lemmiewink
lemmiewink's Avatar
You must be joking...
First off, the turbine wheels are ceramic, not the Compressor wheel. So if they did "blow" the ceramic wouldn't fly into your engine. The shards would just exit your exhaust in a big black puff of smoke.
Op, I don't believe you will see that kind of hp on stock ceramic twins. If its possible, its not for very long.
Old 04-11-10, 03:36 AM
Zar
Zar's Avatar
That list has almost zero power mods.
The guy who selling it is only marginally dumber than anyone who believes the add.
Old 04-11-10, 08:45 AM
nfordhk
nfordhk's Avatar
maybe hes exhaust gives him +50 hp
Quick Reply: 450hp feasible on stock turbos 1.5JZ ?
