SC- 1st Gen (1992-2000)
DIY Wheel Painting!
Old 04-18-10, 12:20 PM
818_sc4
818_sc4's Avatar
Default DIY Wheel Painting!
When i first got the wheels:
Now the tools:
Duplicolor Filler Primer
Duplicolor Paint of Choice
Duplicolor Clear Coat
240 Grit Sandpaper
Prep Wipes /or Paint Thinner
1. Sand the wheel, and excess paint from everywhere and as much as you can.
2. After finsihed sanding, you can wash down with water and soap, then wipe down with prep wipe.
3. Let is dry off, dont forget to use a lintless rag.
4. Spray coat of filler primer, inside the spokes and crevices first.
5. Spray the wheel, steady coats going in same direction, take your time!
6. Clear coat, and your done!!
Should look somthing like this:
Looks Sick Huh? I was debating on painting it looked nice.
After a couple coats, spray your color, again take your time.
Finished product:
Picture on my car. BTW I used duplicolor storm gray.
Old 04-18-10, 12:33 PM
TroySC300
TroySC300's Avatar
Great before/after. Looks good
Old 04-18-10, 12:37 PM
LudeNsoL
LudeNsoL's Avatar
looks good!!
make sure you dont use a power washer..
Old 04-18-10, 01:27 PM
BostonSC4
BostonSC4's Avatar
Looks great!
But, on the finished product picture is that a tad bit of overspray on the inside of the rim?
Old 04-18-10, 02:47 PM
818_sc4
818_sc4's Avatar
thanks
Originally Posted by LudeNsoL
looks good!!
actually when i get it washed i do use a power washer. no probs whatsoever
Originally Posted by BostonSC4
Looks great!
yes it but that is before i sprayed the inside of the barrell black..
Old 04-18-10, 03:07 PM
theory5150
theory5150's Avatar
Nicely done. Are those the enkei's off of the evo?
Old 04-18-10, 04:41 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I think you did a good job. I have used Duplicolor on alot of things and have had real good luck with it.. Almost as good SEM.
Old 04-18-10, 04:44 PM
2turbo1sup
2turbo1sup's Avatar
Looks really good
Old 04-18-10, 05:23 PM
Hil
Hil's Avatar
Nice work, they look great
Old 04-18-10, 07:03 PM
818_sc4
818_sc4's Avatar
Yes sir!! Evo 8 Enkei's
Duplicolor is great if used properly especially in warm weather!
Originally Posted by 2turbo1sup
Looks really good
thanks glad you like it
thank you sir, appreciate it!
Old 04-18-10, 09:10 PM
Sohconthis
Sohconthis's Avatar
Looks great! i think they match the sc's lines perfectly
Old 04-18-10, 09:19 PM
Joey-E
Joey-E's Avatar
Great job..looks good.
Old 04-18-10, 09:41 PM
oneuzfour
oneuzfour's Avatar
Well done...but your lucky the 100 shot NOS didn't blow the welds off the intake!
Old 04-18-10, 09:55 PM
oneuzfour
oneuzfour's Avatar
off topic here.how does one go about painting the outside emblems?will SEM landau black work?
Old 04-19-10, 02:36 AM
czar07
czar07's Avatar
wow looks great man
Quick Reply: DIY Wheel Painting!
