1JZ Vac Route + Fuel Pressure
Need to Confirm 1 of these Vac Ports on the 1JZ. THE DIAG Port Box has a Line coming from Inside section Nipple on the Intake Mani.Shown Here with the Black Circle.Thats the Mystery Line.
I've got all the other ones I believe Correct.
Black: ????
Red: Heater Control valve
Yellow: BLOW OFF valve??
Green: P/s
Blue: Fuel Press Regulator
![](http://img.photobucket.com/albums/v703/Mrfairlady/IMG_1507.jpg)
I'm single Turbo'd:
I'm running the Driftmotion fuel lines, FPR (aeromotive) and Not running the charcoal Canister either but am using the Power steering assist valve from the SC300 Line.
Black: ????
Green: P/s
I'm single Turbo'd:
My Fuel Pressure Drops like Crazy when i turn the car off.Doesn't hold,..but I'm thinking now its because the line over where the canister was is not capped.So Its all leaking out there.It should Hold Pressure for a WHILE.
norcal2jz
Performance & Maintenance
11-21-13 02:28 PM
estomax
05-14-13 07:00 AM
cuda6pak
12-16-10 12:21 PM
