SC- 1st Gen (1992-2000)
Changing Bulb Color in Stock Radio Headunit
Old 05-16-10, 09:49 AM
  #31
snook
snook's Avatar
tttttttttttttttt
Old 05-24-10, 09:04 AM
  #32
snook
snook's Avatar
help thank you
Old 05-24-10, 12:53 PM
  #33
mktbully
mktbully's Avatar
the bulbs are tiny bulbs but they are not LED (they look like small 12v bulbs).
they are all soldered on to the board so you'll probably have to solder them off and solder in LEDs (i recommend SMD instead of LED) and run the correct resistor on to them.
what color LED are you looking to run? check their spec sheet...it tells you what's their typical voltage and what's max. you don't want to run it max.
a 9v battery on a LED will give you a bunch of useless burnts out LEDs. you have to run them w/ the right voltage.
this is from a nak head unit...not sure how the pioneer would look.
Old 05-24-10, 02:15 PM
  #34
Vadim540i
Vadim540i's Avatar
Check out our section today, I've changed bulbs in stock radio and climate control. I will post up details with pics tonight.
Old 05-24-10, 05:31 PM
  #35
snook
snook's Avatar
Hi thanks for your help. I believe that the nakamishi is the same as the pioneer. Where can I get the bulbs that I need? I want to go with bright white.
Thanks
Old 05-24-10, 05:33 PM
  #36
snook
snook's Avatar
Hi what do you mean check what section?
Can you help me find where to order what I need.
I do know how to solder thanks
Old 05-25-10, 06:20 AM
  #37
mktbully
mktbully's Avatar
ummm if you don't know how to solder this might not be a good first project unless you're willing to ruin a radio.
Old 05-25-10, 06:23 AM
  #38
snook
snook's Avatar
Check on your reading comprehension please
Old 05-25-10, 06:44 AM
  #39
mktbully
mktbully's Avatar
sorry...misread that.
my apologies.
i'll be better after i finish this cup of coffee.
Old 05-30-10, 06:25 AM
  #40
snook
snook's Avatar
tttttttttttttttt
Old 06-10-10, 06:15 AM
  #41
snook
snook's Avatar
could use some help
Old 06-10-10, 06:37 AM
  #42
Luv2xl
Luv2xl's Avatar
...ibtl...
Old 06-10-10, 06:49 AM
  #43
snook
snook's Avatar
...ib you are a moron...
oh too late, missed it
Old 06-19-10, 10:04 AM
  #44
snook
snook's Avatar
ttttttttttttttttttt
FRQ
10-30-18 08:23 AM
Hayk
09-02-12 09:20 PM
ChuH
05-14-11 07:14 AM
CLT
09-20-08 04:37 PM
ssaat
12-15-06 06:47 PM
Quick Reply: Changing Bulb Color in Stock Radio Headunit
