backfiring/bogging/shutter - only at 3k rpm at heavy throttle
recently ran into a few problems with my sc300 1jzgte:
the main concern is that it bogs in the 2-3k rpm only.. like it hangs there for a few moments then itll accelerate past the 3k rpm point. at which time ill hear a pop,pop,POW.. (itll also start to shutter sometimes, and try to learch forward) and then ill accelerate throughout the rest of the gear. HOWEVER if i accelerate slowly, as if a cop were behind you, i dont have any bogging throughout the power band.. say anything past 25% throttle and itll bog and miss on occasion.
i recently replaced my clips on the coil packs which made alot of the missing sounds go away (i had a low, very fast, thumping noise at the same time as the louder pow pow BANG).. but this one purists!
mods:
stock 1jzgte
fmic
greddy type s
12v fuel pump mod
3" cat back
relocated battery
im thinking its either the coilpacks, fuel filter, fuel pump, tps, map or fpr.. maybe even of a boost leak?
what do you guys think it is? i thought about putting another fuel pump in but a stock 1jz shouldnt need that right?
mods:
stock 1jzgte
fmic
greddy type s
12v fuel pump mod
3" cat back
relocated battery
being big on dsm's i don't know how much this will help you but i know the problem. A friend of mine had a bad AFPR and his would bog and hiccup just like yours. However if you smoothly got into the throttle it acted fine. He went over all spark issues and couldn't figure it out.
I'm assuming this is your fuel pump taking a dump!
After about a week he found a vacuum line had come undone from the AFPR and the car run perfect after which.
- However if it's a boost leak, you would hear it out of car and it would be alot harder to make boost. Make a boost leak tester and post results. It's never a bad idea to check!
ngk iridiums gaped at .27.. i tried from .30 to .25
and i think its my FPR.. i ran a few vacuum lines off it (heat and boost gauge) and im thinking it cant keep up with all of it? maybe idk, i figured a vacuum was a vacuum
nah its a map.
and yeah ill be replacing a few things to see if thats it. what kind of fuel pump should i get?
edit: did some looking, im goin to try and undo my 12v mod.. i read a few threads with people have the same problems as me.. and its the 12v mod. im thinking it has something to do with the wiring, now i know i wired it right.. because my car runs, but IIRC this problem started after i did this mod (my car was down for a few weeks while i was doing mods to it.. and i dont really remember.. its been like this for awhile now since the 12v mod was the first mod i did)
chrismgiro
RC F (2015-present)
62
09-22-17 05:54 AM
Revhead95
Performance & Maintenance
05-22-12 05:56 AM
SoarerJzz3
12
03-19-06 04:07 PM
