Sc300 5 spd swap questions
I do all my own work so i dont pay for labor. My w58 swap cost me around $650 with all new parts (minus w58, used of course). Then i decided to go single/fuel/ems so i purchased a Soarer R154 with bellhousing, slave, extended shifter for $900. Tranny is mint with 32k on it and not your regular beat the F&%$ out of MK3 R154 with a billion miles on it, so i didnt mind paying top dollar for it. All i have to do now is just get a r154 front DS and a clutch that can hold 600-700 ft lbs of tq and it ready to be thrown in.
You want me too take some pics of an untouched/undrilled shifter housing and shifter extension installed onto my R154?
Next time, do your home work before you come in here correcting my ***. This why I barely post on here, ........F()ckn know it alls
Excuse me??? Yeah you must be 110% correct cuz you did my 5 speed swap a month ago....right?
The hardest thing is drilling ur firewall for the Clutch Master Cylinder. I was upside down on my driver seat with a lethal drill shooting sparks trying to cut a 3 inch hole in my firewall...intense.
Just don't correct me when I'm commenting on things that I have actually seen an done with my own hands.
The offer for the installed, untouch OEM extension housing is still open if you'd like too see it......ma E-thug
Seriously though, back on the topic. Use your PM if you find it necessary.
Not true at all, i havent read all the posts, so im sure this was already posted but heres what i bought and what i needed when i completed my swap
i just got done completing my swap literally 3 days ago. Go to Driftmotion.com they have literally EVERYTHING for the swap..
THings you need: (stock clutch and flywheel will be cheaper)
R154 transmission - $450
1JZ bellhousing - $220
Clutch - $350(NOT STOCK)
Flywheel - $300(not stock)
Slave Cylinder - $50
Master Cylinder - $110 w/hardlines
Hard lines -
BRAKE Clutch Pedal Assembly - $250
1pc Driveshaft - $350(the automatic DS is 3" too short when swapped to Manual)
Driveshaft/Differential Adapter - $160
R154 Shifter Extension - $360
R154 Transmission Output shaft seal - $9
SC300 Manual Shifter assembly w/Boot - $54
TOTAL without installation: $2,663.00
TUNING:
If you dont get the M/T ECU, you can get a standalone tuner, (AEM EMS or piggyback with Greddy emanage or Apexi NEO) - $350
good luck bro anymore questions let me know!!
You can do a W58 swap under a grand quite easily. Its usually the big ticket items that add up. I.E. trans, clutch pedal setup, clutch, ds...everything else is easy japaneezy.
why were you drilling a 3" hole?
what the hell? r154 cost 400-800 in the US? the cheapest one you can find in aus is 1300AUD. most of them are around 1600. thats ridiculous, i could get one shipped for cheaper than buy it here :s
SCjzz
Performance & Maintenance
10-31-08 12:35 PM
soarer NAT
10-01-03 02:49 PM
