where is the coolant going???
Ok I have a 92 SC300 and it has a new water pump and hoses and new thermostat......recently it has been overheating and so I checked the water level and it is almost bone dry...added coolant and no problem. Somehow though it is losing coolant at the rate of a half gallon a week!!!! Ok so did a pressure test and no leaks from the hoses, no crack in radiator etc. etc. Full compression in all cylinders so not a blown head gasket.....wtf is going on??? Anyone had a similar problem? Thanks
Well it is not leaking out of the cap. Could it possibly be coming out the overflow reservoir without the temperature gauge shooting up and alerting me to the issue? Gauge works fine also so it is not the temp sending unit either. This is a mystery problem I have never had before.
Forum Administrator
I've never used it, but I think they sell some sort of dye you can put in your radiator to help pinpoint links.
jgm
08-17-07 08:39 PM
