Quick A/C Compressor Question...
Check the LS forum...this is the SC forum...there might be something on there.
I searched/read CL and Google for four or five days to basically learn all a non-professional could about a/c systems, repairs, etc. It paid off (so far).
I just read your post on the other a/c question thread, you seem to know something about the a/c process...what is yours doing on the LS (or not doing)?
haha absolutely nothing!!!!!!!!!! it was working fine and then quit working...... the compressor doesnt even cycle on no blinking a.c. light nothing. I checked all fuses checked the 2 connections on the compressor checked the hose coming out of the firewall with the line that moves up and down when you move your climate control from hot to cold.. im clueless i also took out the headlight and checked the 3 relays for the fans because they arent working either. I also tried to add freon ( just a little since it was cold last time it did work it couldnt have leaked out very much) because i know the compressor wont cylcle on if its too low on freon. Im so mad haha thanks for trying to help
oh yeah and i forgot to mention that i hooked a wire from the battery to the clutch compressor to see if it works and it does and took off the serp. belt and spun the compressor and it does
2002, 330xi, a/c, a/c compressor, ac, add, compressor, connect, hoses, how much compressor oil, leaking, oil, pounds, r134a, sc400
