SC- 1st Gen (1992-2000)
Switched to supra TT suspension. Car sits higher?
Old 05-05-10, 09:25 PM
djrazr
djrazr's Avatar
Unhappy Switched to supra TT suspension. Car sits higher?
I switched out my stock suspension a while ago, and went with a used TT stock suspension setup with 20kish miles. The stock tt suppose to give you a slightly lower drop 1/2". The rear looks lower, but the front is higher, than stock sc height. Does the suspension, even used have to still settle?
thx
Old 05-05-10, 09:52 PM
Vincent123
Vincent123's Avatar
just cut the springs homie
Klaus
Klaus's Avatar
yeah it'll have to settle. give it a day or so and look at it. Then take it for a slow drive it should settle down
Old 05-05-10, 09:54 PM
Rawtunes
Rawtunes's Avatar
check your end links. i think they should be pointing horizontally
Old 05-05-10, 10:04 PM
BMwhat?
BMwhat?'s Avatar
or you can buy my RS-R springs for Supra TT... brand new in the box! then you'll be low enough... hehehe
Old 05-05-10, 10:06 PM
djrazr
djrazr's Avatar
sorry fellas, i don't like the slam to the ground look, and feel.
Old 05-05-10, 10:12 PM
TroySC300
TroySC300's Avatar
Mine looked higher too and it didn't settle after a few days... I went with Espelier ASD lowering springs.
Old 05-05-10, 11:16 PM
eliteskill
eliteskill's Avatar
wait for it to settle I had TT suspension on one of my last sc.
Old 05-05-10, 11:47 PM
abounly
abounly's Avatar
yeah just let it settle for a bit, it took about a day or 2 of driving for it to settle. I didnt see much difference in the front
Old 05-06-10, 01:24 AM
jadu
live.love.laugh.lexus
Forum Moderator
jadu's Avatar
+1 on cut springs
Old 05-06-10, 02:06 AM
LEX_MAN
LEX_MAN's Avatar
+2 cut em
Old 05-06-10, 08:43 AM
abounly
abounly's Avatar
you guys are doing it wrong! cut the struts! silly guys cutting springs is so old school.. Or if you want to be lower run your car without the whole suspension!
Old 05-06-10, 09:04 AM
PEARL2
PEARL2's Avatar
I notice this happens with the sc300. For those who did cut the front spring, how much did you cut? 1'', 1.5'', 2''
Old 05-06-10, 09:38 AM
JohnEd
JohnEd's Avatar
I installed TT struts made by Bilstien. I have been using Bils since before most of you were born (that doesn't make me smart) and these are the first that have not left me ecstatic. These things are harsh in town but they are a dream at 70 in a 35mph off ramp or at 130 where the "smoothest" freeway can feel bumpy at 80. I tried some sacked TT springs to see if they would pass and the ar was slammed, sorta, at least by my standard. Road rough, too. My cure was to order a Tien spring for the TT. It was one of two options and the other Tien lowered me 2.5 inches and was a stiffer spring and the one I selected lowered the TT 1 inch. So adding the1 inch to the 1/2 that a TT spring is supposed to lower a SC400. Didn't work out that way fo me. My front was raised a couple inches and the rear was down. Can we say "California tilt"? Really old term.
I was stuck with a pile of parts on my car and I was not a happy camper.
THE FIX AND WIN! The Bils have a bottom spring perch that slides down over the shock body. I bought those "adjustable perch" deals for Coil-Over shocks. The Bil perch would not fit over the adjusters so I had the aluminum perches reamed out to sit on the screw up-down perches. HAPPY CAMPER AGAIN.
I am clueless about "why". Tien is a first rate shop and I believe they told me what the "knew".
HTH
John
Old 05-06-10, 09:45 AM
RED95sc
RED95sc's Avatar
^^^ some of the best springs for the SC money can buy, only the eibach is prolly better
Quick Reply: Switched to supra TT suspension. Car sits higher?
