Flush Expert advice!
I need help to make my rear wheels flush as possible.....
Before
![](http://img215.imageshack.us/img215/940/dsc04454l.jpg)
![](http://img685.imageshack.us/img685/7674/dsc04453vs.jpg)
After with 10mm spacer
![](http://img163.imageshack.us/img163/4637/dsc04455b.jpg)
![](http://img413.imageshack.us/img413/5033/dsc04456v.jpg)
Since my rears are getting worn out, I'm planning going 225/35/19 tires... Current rear tires are 275/30/19, would that help make the wheel more flush? OR should I get 5mm spacer?
Before
after the 10mm spacer you put on, your rear wheels look pretty flush to me (from what i can see in the picture).
Now to your question about the tires...
What Width are your 19s?
and how low are you?
i'm running 225/35/19 on an 9.5 width and my stretch is pretty aggressive and helps clear my rolled fenders.
![](http://i801.photobucket.com/albums/yy293/neteru9/SC300/DSCF1334.jpg)
![](http://i801.photobucket.com/albums/yy293/neteru9/SC300/DSCF1317.jpg)
currently your tire is square walled, by putting a 235/35, the tire will start to stretch, allowing more clearance for the tire to go in the fender. at the same time allowing the bead/lip of the rim to poke out of the fender.
right side is a g35, with a 19x10 on 235/35/19 tires. rolled rear fenders, no tire is poking, but just the lip of the rim.
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_6100.jpg)
flush is flush, sunken is sunken, &poke is poke. don't think they all mean flush.
I have 17x10 38 offset. ..running a 275 45 tire....not even with a rolled would these fit..that was the finally word from a shop.that strictly works on scca cars..I'm running a 9.5 38 offset with a 265 40 tire would that clear if the car is lowered 1.5 inches in the rear
