car acceleration lag, smell issue....after installing steering wheel/reseting ECU
For it to work unplugged you'd need to jumper the fuel pump since one of the connections the meter makes is turning on the pump. I don't know which connector pins it is on the SC, I've only done it on the Toyota trucks.
Is it possible to swap only the black plastic sensor part and use my housing pipe? Or does the whole unit need to be replaced?
Also I know from research that the v8 sensor from a sc400 or ls400 wont work right even though numbers are same on the unit. Will one from a 92-95 N/A supra work? its the same motor 2jzge.
Got a new sensor from a local member. Problem solved. Car starts again, but the other problem that I think is the clutch is still there.
The car idles a bit rougher and way louder now then before. I guess this sensor I got isnt in such great shape as my old 93 sensor was. Strangely, this maf was from a 95 sc300.
I havent took it for a hard drive to let the ecu relearn since the clutch problem. Will letting the the ecu relearn help the idle and noise?
THANKS FOR ALL THE HELP PEOPLE!!!!! You guys helped me alot
