SC- 1st Gen (1992-2000)
W58 Swappage
Old 06-03-10, 07:43 AM
  #46
MindCruzr
MindCruzr's Avatar
a W58 swap is definately on my "EXTREME mods" wish list... haha
maybe when the auto goes out... (how long do the 5-speed autos last? lol)
Old 06-03-10, 11:19 AM
  #47
kez
kez's Avatar
auto(4 speed) usually shift solenoids may go
Old 06-03-10, 02:27 PM
  #48
BartleDoo
BartleDoo's Avatar
trans - 200
sc300 manual driveshaft - 175
howe throwout bearing - 150
master cylinder - 75
oem clutch kit - 140
shifter trim - 50
clutch/manual brake pedal set new and marlin crawler bushings from driftmotion - 300 or good luck finding the pedals used
Quantum-Auto kit (flywheel,adapter,clutch lines,howe spacer) - 750
*Or you could upgrade and get the above parts from quantum plus a dual friction clutch kit for 1150. Having never experienced their clutch before I thought it would be extremely stiff so I opted for the oem style. Little did I know how soft the oem feels! Then I felt the quantum clutch in someone else's car and the pedal wasn't that stiff at all. It felt like what I imagined the oem would.
So, 1850 with the cheap clutch or 2110 with a much better clutch. I estimated the shipping costs on some of those that I couldn't remember but it should be very close.
Old 07-09-10, 08:36 AM
  #49
TheRonTom3
TheRonTom3's Avatar
I"m curious as to how you go the bolts into that new trans mount. The bolts that from the mount into the transmission it looks like the SC400 part gets in the way of the holes on the mkIII part
Old 07-09-10, 03:51 PM
  #50
BartleDoo
BartleDoo's Avatar
We welded the fat bolt [that connected the two parts of the MKIII mount together] to the top plate of the MKIII mount [in its original location] and I drilled a hole through the top of the SC's mounts so that the bolt would slide into it. Then, I attached the MKIII plate to the trans followed by attaching the SC mount to that plate via the "fat bolt". Hopefully that is described well enough.
Old 07-09-10, 06:48 PM
  #51
TheRonTom3
TheRonTom3's Avatar
ok i gotcha. Good idea
Old 09-15-10, 06:09 AM
  #52
BartleDoo
BartleDoo's Avatar
Oh yea, I never updated this thread to say that the oem clutch was a no go. It couldn't take the v8. I broke it in well past the required mileage span, but it started slipping. So I installed a quantum-auto clutch and she's been good ever since. I just wish I had been smart from the beginning.
Old 09-15-10, 06:47 AM
  #53
SC YAA
SC YAA's Avatar
wow dude great post im going to swap my 300 this winter and just seeing that you can do it with a floor jack makes it seem not that bad!
Old 09-15-10, 07:08 AM
  #54
trufanatic
trufanatic's Avatar
what did you do about the speed sensor?
Old 09-15-10, 08:56 AM
  #55
BartleDoo
BartleDoo's Avatar
As long as you have tall stands it's not that bad at all.
I used a mechanical to electronic speed sensor adapter from Marlin Crawler for the VSS.
Old 09-15-10, 09:02 AM
  #56
RedPhoenix
RedPhoenix's Avatar
If you use the 6 ton jackstands its fine, anything less, its too low.
Old 09-15-10, 11:20 AM
  #57
mtnrat
mtnrat's Avatar
How does that hook up?
Old 09-15-10, 11:23 AM
  #58
BartleDoo
BartleDoo's Avatar
It threads onto the MKIII VSS and connects to the stock SC harness.
Old 09-15-10, 11:37 AM
  #59
mtnrat
mtnrat's Avatar
I will have a look. Mine is a MKIV.
Old 09-15-10, 02:38 PM
  #60
Gunner1
Gunner1's Avatar
thanks! just what i wanted to hear. i was worried about the clutch being too stiff....i just wanted to read a review of someone who also had that fear experience the clutch. that makes me feel better.
i'm cool with a stiffer clutch, i just dont want to kill my left leg.
i had 2nd thoughts of that howe bearing after reading about people having issues with it...but it was nice to go back to the quantum-auto site to see that they've replaced that piece of the kit.
i would totally buy that basic steel flywheel kit.
i need to first work on getting the car first. lol.
Quick Reply: W58 Swappage
