Hey man good ride. I actually worked on a simliar problem the other day. You need to start your diangostics with the main fuse which is blowing first. Sounds like either a faulty dome switch or a short somewhere in the wire. Check continuity from the power source. You may also have the wrong bulb in there which will blow the fuse. PM me if this doesn;t help and i'll pull up the wiring diagram tomorrow when im at work.
