SC- 1st Gen (1992-2000)
Cracking noise when steering wheel is turned.
Old 05-12-10, 05:22 PM
Vadim540i
Vadim540i's Avatar
Default Cracking noise when steering wheel is turned.
I had this weird problem since I bought the car last summer. It didn't get worse nor improved. The steering rack does not leak or anything. So, when I turn my steering wheel left or right, at first couple of degrees of steering wheel motion there is like creaking/cracking noise from the front end, and then it stops. Did you guys have any idea what might that be?
Old 05-12-10, 05:35 PM
good2go
good2go's Avatar
how are you steering rack bushings?
Old 05-12-10, 05:39 PM
Vadim540i
Vadim540i's Avatar
Where are they located?
Old 05-12-10, 05:40 PM
Gspec
Gspec's Avatar
Ball joints or outer tie-rod ends...
Old 05-12-10, 05:44 PM
Vadim540i
Vadim540i's Avatar
Checked ball joints and they are in good condition. What are tie rods?
Old 05-12-10, 05:54 PM
good2go
good2go's Avatar
https://www.clublexus.com/forums/sus...available.html
(Check out post #29 for view of tie rods too)
https://www.clublexus.com/forums/sus...-bushings.html
Old 05-12-10, 06:02 PM
Vadim540i
Vadim540i's Avatar
Thanks
brainsurge
Suspension and Brakes
11-06-14 07:20 AM
Jake2121
11-15-12 06:00 PM
randee973
02-20-12 04:16 PM
CP_Ree
Performance & Maintenance
01-03-10 08:19 PM
corkycal
07-09-06 09:29 PM
Quick Reply: Cracking noise when steering wheel is turned.
