Need to replace turn signal?
Hi,
My front turn signal light will occasionally not come on when I signal to make a turn. But most of the time it works. Also, the arrow light inside blinks more quickly when the turn signal light is not working.
Anyway, do I need to replace the bulb? I'm not sure if that's the problem since it works most of the time. Usually, if a bulb goes out, it's out for good. Could it be a loose wire somewhere?
Thanks,
Ken
Thanks,
Ken
Hello Ken
I'm betting on a loose connector on the headlight or corroded bulb base. That is unless you have custom wiring on you turn signals. You might as well replace the bulb when you're checking the bulb base.
- Miikka
- Miikka
