Location of keyless remote module?
Hey everybody,
My dealer had to order me a second key for my '92 SC400, but when it arrived, I was informed that the keyless remote wouldn't work because it wasn't paired with the receiver. The chip in the first key is damaged, so I only care about this second key/receiver. He said he didn't know how to install the new receiver (which he gave me), but his contact at Lexus said it's just a simple swap. It looks simple enough, but I can't find the old one to save my life! I was told it was in the back seat, but still can't find it.
Any clues??? Thanks.
Aargh! I just spent the past 30 minutes trying to follow your advice, but I don't see any way to get the rear seat off. Can you steer me in the right direction?
The only possibility I see is a small pin on either side of the gas tank while coming in through the trunk, but I can't budge the pins.
Thanks for the help so far.
Do-luck SC, you're a genius! I got the seat bottom off, but it will be a week or two before I get back home with my tools in order to remove the seat back. I'm sure I'll be able to take it from there, following the directions I found on the "rear seat removal" search (there were photos & diagrams & everything!)
Thanks from the newbie!
How much did the new transmitter cost you because I fell on mine this pass winter. and it does not work so I was thinking of ordering a new remote. And how did you get the new remote to work with the receiver?
mmatheny
05-22-09 11:51 PM
