sc400 audio amp help
Recently installed a new radio cause that's what someone told me my audio problem was. Well it still doesn't work makes the same stupid sound from the speakers dodoododod and now my local audio shop tells me its my amp. They told me I could do 2 4 channel amps or 1 5 channel amp or maybe replace my factory. What should I do?
When you say you got a new radio. Do you mean stock or after market radio? If its an aftermarket you can run new wires to the speakers, then you would only need an amp for the sub. If stock your shop was right. You would need an amp or two. I have an amp that can be 1,2,3,4,or 5 channels. You have to figure out what you want out of your system and go from there. I don't know which would cost less one amp that does everything you need or two (regular) ones.
Yes you can run the speakers directly from the radio. I don't know if you can wire the stock sub amp to the aftermarket radio. If you can there is probably a d.I.y. If you search. Or you could find a stock amp to replace your broken one.
kpkim01
03-05-12 08:19 AM
