SC- 1st Gen (1992-2000)
Changed glove box bulb, and it still doesn't light up.
Old 05-20-10, 10:59 AM
Vadim540i
Vadim540i's Avatar
Question Changed glove box bulb, and it still doesn't light up.
So I changed my glove box bulb yesterday (got it from dealer), and it still doesn't work. Tried to turn on lights, turn on ignition etc, and still same thing. According to manual, glove box bulb and other interior lighting have the same fuse in the driver's side kick panel (fuse #6 "PANEL" 7.5A). All other lights in the interior work, so what might be the problem?
Old 05-20-10, 11:26 AM
Tabaka
Tabaka's Avatar
I didn't even know the glove box had a light lol. I guess I need to change mine as well.
I'm have the same issue with one of my License plate bulbs. Only one side works. I tried to change the bulb that I purchased from the dealer and it doesn't work. I haven't had time to fool with it.
Old 05-20-10, 01:11 PM
Teal Sc400
Teal Sc400's Avatar
Vadim540i, There's a trick you have to do for them to come on, the tail lights/lights have to be on in order for the light to illuminate when the glovebox door is open.
Old 05-20-10, 06:16 PM
Vadim540i
Vadim540i's Avatar
I've tried all possible combinations with lights on, off, engine running etc. And still the same
Old 05-20-10, 07:05 PM
Durrby
Durrby's Avatar
same here '99 400. i'm using that like 15 piece led kit from luxurymods.
Old 05-20-10, 07:12 PM
Teal Sc400
Teal Sc400's Avatar
It states this procedure in my 95 Lexus Owner's Manual. Look in your Owner Manuals. Wait did you buy Led bulbs? If yes...take out the led and reverse connection and then try the steps above.
Old 05-20-10, 07:52 PM
Durrby
Durrby's Avatar
^ don't want to jack the op's thread but since i have the same problem oh well. i tried reversing them as well as trying different led bulbs of the same size and nothing works.
Old 05-20-10, 08:00 PM
horent135
horent135's Avatar
15 piece led for glove box? How that possible?
Check your fuse, the head/tail light has to be on, and try reverse..
Old 05-20-10, 08:23 PM
Durrby
Durrby's Avatar
jackass lol
http://www.luxurymods.com/superwhite...0sc300400.aspx
Old 05-20-10, 09:26 PM
Vadim540i
Vadim540i's Avatar
I was bored at work today and found why it doesn't work. I'll post pics when I'll get home, about an hour later.
Old 05-20-10, 09:43 PM
horent135
horent135's Avatar
LOL, i just wanted you to link me
Old 05-20-10, 10:14 PM
Luxor
Luxor's Avatar
Was the pin switch disconnected?
Old 05-21-10, 01:02 AM
Vadim540i
Vadim540i's Avatar
Yep! And I still can't find where the heck the wire is?!
Old 05-22-10, 07:04 PM
Durrby
Durrby's Avatar
pin switch?
Old 05-22-10, 11:51 PM
Vadim540i
Vadim540i's Avatar
pin switch?
The switch was disconnected from wire, I took off glovebox yesterday, found wire, connected it to switch and now everything works
2010rouge
11-24-16 03:15 PM
spoogenet
05-26-16 06:57 PM
pizdets17
11-09-10 11:01 AM
lexusscturbo
03-13-10 05:30 AM
DAgreenSC
09-27-07 11:09 AM
Quick Reply: Changed glove box bulb, and it still doesn't light up.
