my sc400 project update
Hi guy Its been a while since I last made a post on my car and I have been hard at work. in case you don't remember this is my 92 sc400
![](http://carphotos.cardomain.com/ride_images/3/3359/3321/33396660055_large.jpg)
anyway to the reason Im posting I have finally got around to installing and testing my wet nitrous system and I have to say It's great. I have sparyed a couple of times on a 100 shot and the car love's the stuff.
I did change out the plugs to a two stage colder plug and I am using a wot switch. I do have pic of the system below It is a rough set up though still needs to tucked and hidden I also have to install the rpm switch I have.
![](http://carphotos.cardomain.com/ride_images/3/3359/3321/33396660052_large.jpg)
![](http://carphotos.cardomain.com/ride_images/3/3359/3321/33396660054_large.jpg)
I also went out and bought a kenwood double din nav unit from best buy so here pic of that notice the purge and on switch for the nitrous. still have to pick up a adapter unit for the deck and a new ash tray because mines broke. there a plastic panel I made up to kind of close the gap but it wont be staying.
![](http://carphotos.cardomain.com/ride_images/3/3359/3321/33396660057_large.jpg)
so that mostly it for now but I should be getting ls400 brake soon and then manual trans swap + paint at the end of the year
1JZ Single SC400
Be careful with a hundred shot. I have read on here that 100 shot even with a Dragon Torque Converter can cause some major slipping go on in the tranny. Who cares? As long as you outrun everything you race. On with the mods! Thanks for sharing. You should have done a write up on how to install a 100 shot shot wet system.
sorry it takes so long on my response for this but ya Ill look into doing a right up on a wet nitrous install. I have spent alot of time recently installing nitrous systems. as for the dash kit I had already spent way to much that day. the black button is the purge and the red switch is the arming switch. any way here more pic's of the car
![](http://carphotos.cardomain.com/ride_images/3/3359/3321/33396660056_large.jpg)
![](http://carphotos.cardomain.com/ride_images/3/3359/3321/33396660058_large.jpg)
![](http://carphotos.cardomain.com/ride_images/3/3359/3321/33396660060_large.jpg)
Awesome! Safe to assume you're running stance coilovers? :P clean whip, and one of few people doing NoS on these cars.. though most of the V8 Domestic rodders in my area, all are shooting...
edit: what kind of exhaust are you running?
