i just lost a race my first race in my sc400!
A brand new GTI with 21 psi boost vs a 15 year old stock SC400 with a 4-spd autobox... how was that even remotely a fair race? I have a feeling even a stock GTI could be the SC400. Our ancient tranny is half the problem. Because its only got 4 speeds, its hard to shift into the right RPM. One of the worst things is that the gear shift from 1st to 2nd drops the RPM to 3450, well below our torque peak of 4400-4500.
One of the first mods Blizzy did on his SC400 was swap the rear diff, going from 3.92 (stock) to 4.27. That alone improved his 0-60 time from 6.78 secs to 6.45 secs, with his best run hitting 6.37 secs:
http://www.lextreme.com/forums/showthread.php?t=7745
Mind you, this was before he went for a 5-spd manual. Changing the gearing on our cars alone makes a world of difference.
hahaha...this is such a fool's game though. You are chasing your own tail.
No matter what you do to your car, someone will ALWAYS be able to beat you. There will ALWAYS be someone faster...that's what makes it such a sport. You need to set a goal for yourself, be happy with it, and quit looking at what kind of car just beat you...because that is ALWAYS going to be a moving/never-ending target
You would have to kill me, then stuff my dead corpse into a GTI before you'd ever catch me behind the wheel of one of those things. VW is the definition of a POS Eurobox, and hatchbacks are for people who call their husbands and wives, "partners"
Bottom line is the SC is not a good platform for speed if you don't have quite a bit of money to spend on it.
GL
Ryan
Bottom line is this. If your worried about beating GTi's, SRT4's, WRX's, or other mid-displacement 4 cylinder cars, you HAVE to go forced induction(SC's have huge heavy asses, and the stock auto is just killing the little hp the JZ and UZ engines make). You can keep the stock auto, but like with my SC300, it really limits everything from HP to launch control (unless you dish the cash for a TH400) and is still an auto.
I dont know how the UZ reacts/responds to low boost, but a stock 2JZ-GE is a decent contender @ 9psi (estimated 290-330rwhp on stock compression/fuel), and is enough that I dont even look at or bother with turbo charged 4 cylinders..and in the next few months much bigger game will be on my menu...
just swap the UZ, or dump some money into it, go with an R154, FI, good suspension, then go after the GTi.
All three of these take in the upper part of a 1k or more to do but he's options are limited if he want's performance from car he has to pay for it or get a new car. It's a luxury car.
[QUOTE=nerdyimage;5530199 He has a 2009 golf gti pushing 21psi stock turbo (which everyone already knows just making it clear)[/QUOTE]
First off I dont know of any car mfg that is pushing 21psi stock. And if he is running 21psi, hp/weight ratio, he's killing you. That car is close to 1000 lbs lighter that you. Your car stock is making 180hp to the ground. 21psi he's probably making close to 275-300 to the ground. (assuming other mods, not just 21psi). There's not a whole lot of bolt on's out there for the 400, but there's enought to get you another 30-50 hp. It cost alot of money to make a 400 fast. Good Luck.
Sorry this topic LOL went fast,started typing on the 15 & I was 29 when posted. ALOT of the same points made, by many.
