Need help asap!!!
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
hey guies i got a problem that i hope you guies can help me out with.
so heres the situation..
when i try to signal with my turning signal switch nothing works,
but when i turn on my emergency lights all of them work "signal lights"
does anyone know what this can be?
is this common in the sc300's?
any help would be great
thanks,
matt
thanks,
matt
I had the same problem when I messed around with my head-unit. My signals and horn stopped working, the fuse had blown. And as soon as I would use the horn the new fuse would blow too. I tried replacing it with a bigger fuse but that didnt last long either. I could never figure out what caused the issue.
Your signals arent working cuz u blew a fuse. Look under your hood for the one that corresponds to your signals and just replace it. Hopefully you dont end up with the same problem I had, otherwise its an easy fix.
thanks for the quick reply
i checked them just now and everything is fine as far are the fuses goes.
could it be the flasher?
does anyone know where the location of the flasher for the turning signals is on
an sc300?
an sc300?
