Traction control light on?
Take it somewhere that will pull the code for you for free (Autozone, Checker, AAMCO, etc). They should give you a clue on what it might be. Could be anything as easy as your gascap loose, to something more involved.
As far as the traction control, I think you are mistaking it for the bulb-indicator light. This usually indicates that you have a brake light, running light, etc that is out. Have a friend help you find it. Tap the brakes, check your signals, check your plate bulbs, running lights, etc.
Hope this helps.
Hope this helps.
blkis_250
05-23-20 01:53 AM
TroyzLegit
08-18-18 03:07 PM
