SC- 1st Gen (1992-2000)
No current to Injectors..HELP
Old 06-10-10, 05:31 PM
Track5tar
Track5tar's Avatar
Default No current to Injectors..HELP
i have had this problem getting my SC to crank for a little while now. It started when the car just started acting like it was running on 4 cylinders...I was going about 40 when it just start going really slow and shaking a little. I have done my research and replaced soooo many parts. I have come to a conclusion i believe and would like a little help.
Yes i have already looked at other threads/posts as well.
Parts I've Replaced so far:
Fuel Pump
Fuel Pump ECU
Ignition Coils ( Both sides )
Injectors
Spark Plugs
Spark Plug wires
Rotors Caps all that
Cleaned MAF
Coolant Temp Sensor
Ignition switch
many other things im sure i forgot something..
Finally something i should have been checking..
I realized that none of my Injectors were getting current so I think the ECU is causing it..well thats what most have told me and studies show that cause this.
Any advice on the best aftermarket ECU for a just about stock 92 SC400? I just have deleted resonators and Magnaflow mufflers..or where i could get OEM ecu? Alot of guys on here dont have it that i have Pmed..
any advice greatly appreciated..
Thanks.
But i noticed that i am not
Old 06-10-10, 05:33 PM
Track5tar
Track5tar's Avatar
oh yea..when i got my little brother to push foot down on gas i squirted a little gas in throttle body and every time i try to crank it right after it almost starts! like it starts and dies real quick. Thats what led me to see the injectors were getting no current. Nothing else could be wrong. ive double even triple checked some of these things..
Old 06-10-10, 06:57 PM
cartmill
cartmill's Avatar
how are you verifying that the injectors dont have power?
also, i have a 92 sc400 ECU i could sell you
Old 06-11-10, 11:11 AM
Track5tar
Track5tar's Avatar
turned key to on position and checked each wires that go to injectors with amp meter
how much? and condition?
Sc4kid
Performance & Maintenance
06-23-17 05:52 AM
SC300_704
22
07-05-11 09:38 PM
V8drummer
29
06-14-11 11:01 AM
Meanshyguy
02-09-11 08:34 PM
RAINBOW
22
09-21-10 07:57 AM
Quick Reply: No current to Injectors..HELP
