Do NOT forget about your Fuel Filters!
i had the one changed in my 93 LS and boy was it rusty..the mech almost couldnt rethread it..thats how shot it was. also its good to change it when the tank is low so u dont lose that much gas.
But really, just get a quality tubing wrench and use some pb blaster like Net said
Lol...i started out JUST changing my fuel filter and fuel pump a few days ago, i ended up stripping the flare end nuts on both sides, so i had to replace my fuel lines...So i though, though some more, and thought a tad bit more and said,"Well since im replacing it, i might as well..." Now im in the middle of building an E85 fuel system.
i say let PB Blast eat at it for a day or two.
fyi on these 'spray wrenches'....try some TRI-FLOW, comes in a black aerosol can with orange and yellow printing....the best I've found, removed my exhaust manifold bolts (all 12) from my 64 Ford original 292v8 pickup with socket wrenches and no heat, to replace with headers..... soaked and tapped them every day for 5 days, works on stuff like this that you're talking about, ...a little expensive, but it's worth it. Not at auto parts store, only a good hardware store.
i suggest you guys use a flared nut wrench when breaking the nuts loose. make sure you have another wrench securing the fuel filter. liquid wrench is your friend. Being in CA helps a lot also lol.
