What size spacers for GS wheels?
I want to bring my rims a little more flush until I can find/ afford a nice set of TT chrome 17s... I'm thinking 10mm spacers in the front and 15mm in the rear... I'm pretty sure the stock offset is +50 so with the spacers it would put me at +40/+35 respectively... I know I have stock suspension big tires and small rims, but can u guys help me out till I can upgrade?
(btw. I will be doing spacers/studs, rotors, pads, and lines all at the same time
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs553.snc3/30284_648238029036_40502647_37392786_6313007_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs533.snc3/30284_648237310476_40502647_37392722_5749930_n.jpg)
these are the best shots I have to show how sunken the wheels look now...
Get some 25mm spacers from Nigel at JDM Imports. He sells them for 125 shipped and is a CL vendor. 15mm cost the same amount and you will not notice much of a difference. Get version 2's so you don't have to replace your studs. Make sure to get an alignment immediately after. You should probably consider lowering springs or coilovers.
grekt
05-16-17 07:26 PM
