Godspeed Gte Intake Plenum
http://cgi.ebay.com/ebaymotors/97-su...Q5fAccessories
Has anyone ever used one of these plenums with their 2jzgte swap or known of anyone using one?
It looks to me to be of reasonable quality and for the price you cant beat it.
Some may be concerned that it has no velocity stacks inside of the plenum but I will be doing some work to this manifold before it goes on anyway so it is of no concern to me.
Thanks Guys
Thanks Guys
This is the manifold I was planning on modifying to work with the GE lower runners to replace the JDM GTE ffim I have in place now. Havent seen anyone using them personally, but Im sure with a bit of work (cleaning towards the runners if needed) it could be a pretty nice piece for the price.
my only concern would be what TB to use? I had planned on a 90mm Wilson TB, but am thinking the flange would need to be cut/modified/swapped out.
Not to sure about the godspeed one but i know the pnt which comes with the lower runners also has been proven on some fast cars in the supra world. Im just going to be keeping the stock manifold as its not that restrictive and ill be using the money in other places which will show better power gains (i.e. headwork)
Thanks for all the responses guys! I'm actually planning on using this on a GE. It says in the ad you can use the stock throttle body. the reason I was looking a this is mostly because there will be no way the stock GE intake will clear the hood nor the cowl of my 97 Firebird (and who doesn't love a FFIM). Ill let you guys know when I get this fabbed how much work it is to get it mounted to the runners. I hope to make over 900 crank horsepower when all is said and done.
I have too, and they are $400 more than the one for the GTE..hence, modification to the GTE intake for $300. I have been working on and researching GE alternatives to over priced aluminum intakes..I can justify an aluminum intake that is made from a few pieces of aluminum, no flow charts, no warranties, no TB's or vacuum ports that go for $600+, its just retarded..hand made or not. So by looking into this, if I can accomplish something simple, inexpensive, and ultimately complete (TB, TPS, Vac ports, etc..) for less than $500, it pays off for all GE na-t owners/builds.
Shortly after I get moved this week, I will have one of the GTE Greedy styled intakes from ebay in my garage with my spare set of GE lower runners..if all goes well, or I can find a simple solution, I will share the info.
