Trunk Popper Problem
So out of nowhere the trunk release switch no longer pops the trunk :-/
The switch is also wired to my Viper Alarm and it also will not electronically pop the trunk. Manual key works just fine.
If I disconnect the battery and then reconnect it (was doing something else, found this on accident) the trunk will pop on its own![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Ideas?
It is not the valet....checked that first thing.
Ideas?
wow this is awesome - just happen to be replacing my struts. I came across this thread, went out, and unlocked my valet switch thru trial and error and hot damn, my trunk-release switch is back in actiooooon !
thanks
thanks
I just fixed mine too. For the longest time the key-switch under and left of the steering wheel wouldn't pop out using the master key. I wiggled the hell out of it last night and it finally popped out and now it works. Maybe some WD40 is in order here.
Marzabella
12-04-11 02:38 PM
