sc400 bucks under hard acceleration
i am a first time lexus owner and my 95 sc400 runs smooth untill i punch it and then it starts to buck and almost like its losing power. it has 145000 miles and i have had it 3 days . any ideas?
with engine running and nothing on the voltage is 13.7. im starting to think its a fuel delivery problem. that dang filter is really hard to undo the nuts.
Does run smooth until about 3000-3500rpm? Timing belt may have jumped a tooth if your tensioner got loosened up. You can hand line up the timing marks on the crank and cams to check this.
try your coils pack mine did the same at 3500 and as soon as i changed it i got my power back. or fuel filter which is a pita to change cause i bought mine from someone and it never was changed so it rusted on there
well after totally mangling my fuel filter and having to cut the lines and adding rubber fuel line with the filter, and checking everything under the hood .i pulled the plugs and cleaned them and the caps and rotors, but it still missed and ran like sh*% . so i decided to put new plugs and wires, which btw are a pain to change. the car runs great.. thanks for all of your help..
aumsc400
SC- 1st Gen (1992-2000)
30
10-13-15 09:42 AM
