SC- 1st Gen (1992-2000)
INJEN Intake problem please help
Old 06-28-10, 09:07 PM
socal72
socal72's Avatar
Default INJEN Intake problem please help
i just installed an injen intake on my 95 sc400 followed all instructions cleaned throttle body and MAF with CRC MAF cleaner. fired it up and it didnt want to start at first untill the cleaner circulated through fired up and immediately coded. i let it idle to operating temp then took it for a drive the hesitation i had is gone and fells real good untill you really put your foot in it then it wants to cut out let off a little and its fine .i dont know whats wrong any one have any ideas?
Old 06-29-10, 10:00 PM
socal72
socal72's Avatar
i took it all back apart and put it back together again and still got the same result.my fear is that i messed up the MAF sensor with the CRC MAF cleaner. does anyone have any input ? i read some of the other threads about crc maf cleaner and they said it was fine which is why i used it but now reading the can it says not to use on toyotas and some lexus models with a karman vortex intake. im tempted to just put the stock stuff back on and just get rid of the injen intake.......can someone shed some light on this matter?
Old 06-30-10, 06:31 AM
fried_rice
fried_rice's Avatar
Are you sure you reconnected everything correctly? Maybe you can find someone local to test a different MAF. You should also pull the code then try resetting the ECU by unhooking the battery for a few minutes. It definitely sounds like the MAF though.
Old 06-30-10, 06:36 AM
Tabaka
Tabaka's Avatar
I'm with Fried Rice, disconnect your battery and reset the ECU. If that doesn't work then
test another MAF.
Old 06-30-10, 09:06 AM
socal72
socal72's Avatar
thanks i'll try that and see if that does it and get back to you guys later today.
Old 06-30-10, 09:21 AM
UT93sc300
UT93sc300's Avatar
The cleaner broke my MAF on my 93. Does it run super rich and stall out if your not pressing the gas?
The cleaner is not good for the vortex air flow meters (which i think is what 92-96 has). I know my 93 has the vortex.
My money is on the vortex AFM.
Old 06-30-10, 09:36 AM
socal72
socal72's Avatar
no it seems to run good untill i try to go WOT then it cuts out and will stall if i keep my foot in it which i dont but seems like it would. and idles a tiny bit rough.
Allaretake
Allaretake's Avatar
I think you might have fried the MAF by using the wrong cleaner.
Old 06-30-10, 04:31 PM
socal72
socal72's Avatar
i think your right ,shouldnt their be a change when the car is running and you disconnect and reconnect the MAF if so theres no change except for when you drive it and it will do what i said earlier it, oh yeah ive been driving like this to because its my DD hope im not messing something else up by doing this . so i guess im in the market for a MAF anyone want to sell one to me?
Old 06-30-10, 06:40 PM
t70 supra
t70 supra's Avatar
u need tpo use compressed air not crc stuff ur a karmen maf
Old 06-30-10, 11:26 PM
socal72
socal72's Avatar
thanks for all the feed back guys. so i guess i'll buy another maf and just use compressed air to clean it. but it would be ok to clean the intake with a cleaner like valvoline synpower carb,choke and throttle body cleaner right? and maybe hold open both butterfly's with something, stuff a rag in the bottom of the bore so it soaks up the cleaner then use the rag to wipe out the throttlebody does that sound right to any one ? or will that also hurt some thing?
Old 07-01-10, 06:10 AM
horent135
horent135's Avatar
It is ur MAF, one thing I learn about the SC, NEVER let the MAF touch any kind of liquid.. I dont care if it cleaner, water or some other type, it has to be DRY otherwise, your idle will go crazy.
Old 07-01-10, 10:37 AM
socal72
socal72's Avatar
well i have a couple of maf's on the way,but in the mean time its ok to drive this way right? its not going to ruin anything like the O2 sensors or cats egr,etc...?
Old 07-01-10, 10:55 AM
Vadim540i
Vadim540i's Avatar
You probably damaged your MAF with that *cleaner*.
Old 07-01-10, 06:48 PM
socal72
socal72's Avatar
yeah i think your right too .its ok to drive like this right ? at least untill my others come...i can go like half throttle before it wants to cut out..
Quick Reply: INJEN Intake problem please help
